Which Mass Air meter is better? - Mustang Evolution
Old 02-12-2012, 12:47 PM   #1
91coupe's Avatar
Going to upgrade to 24 lbs injectors. Which mass air meter is better the C&L meter or the Pro M meter. The C@L meter is about $150 and the Pro M is about $210 both from late model restoration.
91coupe is offline   Reply With Quote
Old 02-12-2012, 01:33 PM   #2
Re: Which Mass Air meter is better?
Neither one.
IMO the best MAF made today is the ABACO MAF
You don't have to go through a plethora of sizes trying to decide which one is best for your combination. There is an 85 MM for small cubic inch engines and a 97 MM for larger cubic inch engines along with a belled 97 MM for draw through forced induction engines.
You do not have to send them back in for re-tuning if you change injectors or if the tuning map is just not right for your combination. You can tune them yourself with a desktop or laptop computer. They have lots of tunes that you can download and you can tweak them to your needs or use them as is. They will hold up to 10 different tunes/calibrations that you can access with the turn of a screwdriver.
Originally Posted by Summit Racing
Are you ready to be impressed? Abaco Performance has developed DBX mass air meters that can be used in virtually any application or configuration. Besides being the only digital mass air meters on the market today, Abaco DBX meters eliminate worries about maxing out your mass air meter. They can be re-flashed to change calibration and programmed to hold 10 calibrations. They work on multiple makes of frequency and voltage-based autos and utilize a built-in digital response filter to eliminate much of the "noise" without sacrificing response time to airflow changes. These DBX meters work great with draw-through or blow-through applications and their multi-sensor design allows the meters to be installed in any configuration, at any clock rotation, without signal deterioration. Abaco DBX mass air meters are made from extruded aluminum, not plastic, for strength and durability and are designed with an easy plug-in for USB cable hookup to your PC. You'll be impressed with their crisp throttle response, stable signals, and unparalleled drivability, plus the included free software allows you to custom-tune fuel curves to grow with your performance. So, are you ready to be impressed? Bolt on Abaco DBX mass air meters and kick up the horsepower on your ride.
Summit Link
Old 02-12-2012, 02:09 PM   #3
91coupe's Avatar
Wow that meter is pretty high tech. Another question I should have asked first is do I even need to upgrade to bigger injectors? I've go a cai, 70mm tb, cobra intake gt40 heads roller rockers and the ford b cam.
Old 02-12-2012, 02:44 PM   #4
WhiteCobra94's Avatar
75mm Granatelli Motorsports MAF for 24lb injectors is $260
Old 02-12-2012, 02:48 PM   #5
A set of 24 lb injectors would certainly compliment the mods you have.
Do you really "need" them?
You can get by on the factory 19 lb injectors until you get a bit over 270 HP.
See the calculator at the bottom of this page - RC Fuel Injection
Old 02-13-2012, 11:00 AM   #6
Meansaleen's Avatar
I have a c&l maf and ford racing 24lb injectors for sale. Maf is calibrated for 24 lb. check classifieds if interested.
Meansaleen is offline   Reply With Quote
Old 02-13-2012, 11:26 AM   #7
91coupe's Avatar
Ok I'll check it out. But I've already got a set of injectors. Took them off a Lincoln town car or something at the junk yard.
Old 02-13-2012, 02:17 PM   #8
stampde's Avatar
Pro-M used to make Granatelli's Meters , not sure if they still do ?
I've always used Pro-M with no issues !!!
2011 GT Auto
speed density vs mass air flow Giles85 1979-1995 Mustang GT 4 02-03-2012 06:30 AM
Diablo MAFia Mass air calibrator GTtopgear 1996-2004 Mustang GT 4 12-18-2011 06:16 PM
Mass air upgrade deadsp0t 1979-1995 Mustang GT 8 10-13-2011 01:18 PM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
04:54 PM
