EGR - Mustang Evolution
Old 02-13-2012, 08:34 PM   #1
captain78's Avatar
EGR
Why do some people run the EGR plate and some don't what's up with that.
captain78 is offline   Reply With Quote
Old 02-13-2012, 10:00 PM   #2
Re: EGR
Well, back in the day the EGR ran under the carbureted intakes and you could gain some HP by removing the EGR and blocking off the channel, thus promoting cooler denser air flow in the intake.
That thinking has carried through, but recent research has shown that there is actually very little if any benefits to be gained from removing it.
The EGR valve closes off under WOT so the flow of the heated gases is temporarily stopped anyways, right when you need it to be stopped the most.
The only other reason to remove it is because the EGR system components have been removed or damaged and it is no longer able to do its job anyways. Racers will remove it to save weight and reduce the under hood complexity.
Old 02-14-2012, 06:56 AM   #3
captain78's Avatar
Is there a particular way you should remove it or do you just take it off. The reason behind it is because I bought all my stuff. Intake. TB. CAI. MAF. Underdrive pullies. And distributor and realized I didn't get a EGR plate. And was wondering if I even needed one. Now there only $75 compared to what I just spent but on ther other have it is $75 and if I have to buy some kinda delete kit that's gonna cost $25-$50 I might as well get the egr plate
---------- Post added at 07:56 AM ---------- Previous post was at 07:42 AM ----------
My next question is I have a 75mm BBK TB should I go with a BBK 75mm egr or can I go with and different brand 75 mm egr plate
Old 02-14-2012, 09:03 AM   #4
WhiteCobra94's Avatar
I took out my smog pump and EGR, just get a blank plate with gasket and block the opening up
Old 02-14-2012, 09:39 AM   #5
captain78's Avatar
Yea my smog pump is still there but that's getting yanked SOON. But I I been thinking of just buying a egr plate instead of the hasle of blocking and plugging and tricking computer type stuff.
Old 02-14-2012, 10:21 AM   #6
That's what I did and it seals up the EGR
Old 02-14-2012, 02:47 PM   #7
Re: EGR
You will likely get a CEL light from the ECU.
You can buy (eBay) or fabricate and install an EGR Eliminator to turn off the light.
Any brand 75MM EGR plate will work if you decide to keep it.
Name:	EGR CEL Eliminator.gif
Old 02-14-2012, 03:29 PM   #8
captain78's Avatar
Lol yea I don't get the diagram lol but thanks I just got off eBay and I can get complete kit like $75. That's the egr eliminator the block off plate and delete plate
Old 02-14-2012, 03:36 PM   #9
Re: EGR
The diagram is easy.
You just solder the resistors together as shown and run wires from them to the EGR connector terminals as shown.
Old 02-14-2012, 04:00 PM   #10
captain78's Avatar
Easy if you know what you looking at lol. This is all new to me I'm use to my 77 that don't have all the computer and sensor stuff
Egr info Matt5.0 1979-1995 Mustang GT 17 01-15-2012 02:19 PM
Egr valve Matt5.0 1979-1995 Mustang GT 5 01-02-2012 09:15 PM
Egr bypassed Travis B 1979-1995 Mustang GT 1 11-22-2011 08:28 PM
EGR troubleshooting? Nate98stang 1996-2004 Mustang GT 3 11-04-2011 01:23 PM
Egr valve and evr tbonestang 1979-1995 Mustang GT 18 08-03-2011 04:59 PM
02:28 AM
