aode problem - Mustang Evolution
Old 11-27-2007, 06:53 PM   #1
aode problem
hello guys i have a 95gt with the aode it was rebuilt about 4 years ago with shift kit i think with more or different bands?
The problem is when in high gear and overdrive it stops pulling the engine will rev up like it is in neutral until a higher rpm and then pulls again. but still not at lower rpms the only thing i found to get it to be ok is to pull it down in second back to drive and its fine
has anyone had this problem or might no what it is.
thanks
today i drove it and it wouldnt go in to drive at all
dbiser is offline   Reply With Quote
Old 11-27-2007, 09:14 PM   #2
eagle05's Avatar
Re: aode problem
I would start by changing the filter and see if you have any junk in the pan if theres any band material in the pan its real bad news if the fluid smells burnt your cooler may be stopping up. if the pans clean change the filter and refill with fluid and see if that helps if not it sounds like a trip to shop at my house.
:drive:95 GT T5 K&N filter B&M Pro ripper kicked the cats out and flowmasters :burnout:
eagle05 is offline   Reply With Quote
Old 11-28-2007, 07:21 AM   #3
Re: aode problem
It sounds like the band for the gear is slipping but you never know, do the little things like mentioned above to see. If all else fails put in a T-5 and it will be more fun to drive, lighter, faster, and better on gas.
Old 12-09-2007, 03:44 PM   #4
Re: aode problem
hey guys i want to say thanks for responding to the post. the problem was the transmission range sensor or also the mpls sensor every place called it one of the two but that is what it was.
thanks again
Old 12-09-2007, 07:07 PM   #5
rocknbronco's Avatar
Re: aode problem
Got to love computers in the tranny at times.
rocknbronco is offline   Reply With Quote
Old 12-30-2007, 09:56 AM   #6
Titus Wadicus
svtlx's Avatar
Re: aode problem
aod owner says solenoids are for starters...lol
Old 12-30-2007, 12:11 PM   #7
Re: aode problem
lol
AODE shifting too early randyrobertson 1979-1995 Mustang GT 2 07-04-2010 12:30 AM
aode dead end? mark cr8zy Pre-2005 V6 Mustang 6 10-29-2009 10:54 AM
95 3.8, aode trans, and black 95 hood FS fast64 Mustang Parts for Sale and Wanted 0 10-09-2004 10:11 AM
AODE and 4R70W? RedDragonV6 Pre-2005 V6 Mustang 3 01-21-2004 05:20 PM
02:07 AM
