Smog delete - Mustang Evolution
Old 02-14-2012, 03:55 PM   #1
captain78's Avatar
Smog delete
Ok so I've read that you have to have either a smog delete kit our a A/C delete cause you can't just pull them off and get shorter belt. Especially if you have underdrive pulleys. Why is that? Will I be ok if I ditch my smog pump and go with just a smaller belt and keep my A/C and underdrive pulleys.
captain78 is offline   Reply With Quote
Old 02-14-2012, 04:11 PM   #2
here is a diagram
Old 02-14-2012, 04:22 PM   #3
captain78's Avatar
Is that for 87-93
Old 02-14-2012, 04:23 PM   #4
Foxtrot's Avatar
It should be ok. When I bought my mustang it didn't have the smog pump and I removed the ac with a delete kit and just got a smaller belt. I don't see the pulleys being to much of a problem just double check
Foxtrot is offline   Reply With Quote
Old 02-14-2012, 04:23 PM   #5
captain78's Avatar
Cause that's what I needed to see. But I'm also goin with underdrive pulleys that's prolly gonna shortin the belt a Lil bit more
Old 02-14-2012, 04:32 PM   #6
yes it is. here is what i bought.it comes with everything.http://www.latemodelrestoration.com/...ehicle=Mustang. but if i was to do it again i wouldnt install UD pulleys and the charging issues that came with them.
Old 02-14-2012, 04:34 PM   #7
88fox's Avatar
I have ud pulleys and bypassed the smog pump with a shorter belt and I don't have any issues
88fox is offline   Reply With Quote
Old 02-14-2012, 04:37 PM   #8
what u can do is take your stock belt and cut it to the right length.then duct tape it together.take that to the auto store and match it to the length u need.a string will work also but i prefer using the belt cause it sits in the pulley properly when measuring.
---------- Post added at 05:37 PM ---------- Previous post was at 05:35 PM ----------
not everyone does have issues with the charging.but i have read this problem around here lots of times and also have experienced it myself.the cure if u do have charging issues is to use a higher amp alternator.
Old 02-14-2012, 04:41 PM   #9
captain78's Avatar
Well I'm keeping my AC. Ac is like American express don't leave home without it. I already have underdrive pulleys. I'm just goin to pull my smog pump off and get the shorter belt. The idea of cutting belt and shorting and using duct tape is good idea might do that
---------- Post added at 05:41 PM ---------- Previous post was at 05:39 PM ----------
Lol I already have charging issues due to a 20 yr old alternator but I have a chrome one wire 160 amp alternator to replace it. So that should cure my prob
Old 02-14-2012, 04:43 PM   #10
i prefered the removing the ac for cleaner enginge bay look.i also have the luxory of dropping the top. since u already have the UD pulleys with no probs u should be ok.
Old 02-14-2012, 04:43 PM   #11
88fox's Avatar
I agree every car is different I guess you can also say lucky that I didn't experience charging issues . As far as getting the right size belt you can also go to you're local autozone and see if they let you try on the belts that's how I did with mine
Old 02-14-2012, 04:45 PM   #12
thats a good idea if they are nice enough to do that.
Old 02-14-2012, 04:50 PM   #13
captain78's Avatar
Lol guess I'm lucky cause my brother is the commercial manager of the local Oreillys
Old 02-14-2012, 04:53 PM   #14
88fox's Avatar
Lol there you go
Old 02-14-2012, 09:45 PM   #15
captain78's Avatar
Thanks TH. When you gonna sell me that fuel pump you just got lol
Old 02-14-2012, 09:47 PM   #16
Re: Smog delete
Which one do you want? The 255 LPH?
Old 02-14-2012, 09:52 PM   #17
captain78's Avatar
Yep that's what I'm looking for. So I don't have to worry about changing it again with different mods
Old 02-14-2012, 09:59 PM   #18
Re: Smog delete
PM Sent.
Old 02-15-2012, 07:26 PM   #19
89 Foxloco's Avatar
Whats the good thing and bad thing about deleting the smog pump??
89 Foxloco is offline   Reply With Quote
Old 02-15-2012, 07:33 PM   #20
captain78's Avatar
Bad thing is you'll fail sniffer test when getting inspected. And good things are cleaner engine bay less drag on pulleys frees up a couple of hspr not much.
Old 02-15-2012, 07:36 PM   #21
+ 1 and drop a couple pounds
Old 02-15-2012, 07:40 PM   #22
captain78's Avatar
Lol thanks I knew I forgot something
Old 02-15-2012, 08:05 PM   #23
Haha just thought I'd throw that in
Old 02-16-2012, 11:54 AM   #24
89 Foxloco's Avatar
In yore opinion, is it worth it??
Old 02-16-2012, 12:01 PM   #25
WhiteCobra94's Avatar
I think it's worth it but my car is not a daily driver so I keep it under 5,000 miles a year and my emissions gets exempt !!!
Old 02-16-2012, 01:40 PM   #26
captain78's Avatar
Depends on where you live and the laws. I live in Louisiana so it's worth it to me
Old 02-16-2012, 08:24 PM   #27
89 Foxloco's Avatar
Oh ok . Thanks guys...
Spoiler delete haters SD06stanger 2005-2010 Mustang GT 75 02-29-2012 10:19 PM
Muffler delete Patcurrie008 2011-2014 V6 Mustang 25 02-16-2012 09:27 PM
Fog lights delete 02utahgt 1996-2004 Mustang GT 0 02-07-2012 12:17 PM
cat delete Supertzi 2011-2014 Mustang GT 18 02-03-2012 01:51 PM
smog test secomejia 1996-2004 Mustang GT 4 01-09-2012 06:01 PM
03:10 AM
