Brakes Vacuum Question - Mustang Evolution
Old 02-13-2012, 10:06 PM   #1
MC770's Avatar
Probably completely unrelated to the video you linked to here but you seem to know a bit about fox's. So here is my question for you every time i turn off my 1990 mustang the vacuum that is supposed to be stored in the brake system for temporary braking completely disappears making the pedal rock hard to push as soon as the car turns off. Any idea what could be causing this?
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 02-13-2012, 10:12 PM   #2
Re: FREE Operation Mustang Web Show JUST posted!
Sounds like you might have a small hole in the brake booster diaphragm or a vacuum check valve that isn't holding, but let's see what Doc thinks.
Old 02-13-2012, 10:20 PM   #3
MC770's Avatar
The vacuum check valve is that something I cous see with just my eyes if it's working or not?
Old 02-13-2012, 10:34 PM   #4
No, you could not tell by just looking. You would have to remove and test it.
Air should only pass through it in one direction. You can use a vacuum tester or your mouth to check it.
Try to find a vacuum diagram for your car in your Chilton's or Haynes manual or in a Google search and see if the system has any check valves in it that are related to the brake system.
You could also use a vacuum tester to check the brake booster diaphragm for leaks.
Old 02-14-2012, 11:54 AM   #5
MC770's Avatar
Damn really dont feel like taking things apart... Oh well I'll go pick me up a Haynes or chilton manual later and get to it
Old 02-14-2012, 03:04 PM   #6
Be sure to check before you buy to ensure it has all of the diagrams you need.
Old 02-14-2012, 09:12 PM   #7
MC770's Avatar
Will do thanks
Old 02-14-2012, 09:28 PM   #8
Re: Brakes Vacuum Question
Matt,
I moved these posts to the 79-95 forums, to clean up Doc's thread.
Old 02-15-2012, 11:11 AM   #9
MC770's Avatar
Ok thanks man
brakes squeaking help!!!!!! really annoying austinknoll Pre-2005 V6 Mustang 11 02-16-2012 09:31 PM
Turn signal question 88gtCc 1979-1995 Mustang GT 5 02-15-2012 11:53 AM
Question Dogbitdude Classic Mustangs 21 02-14-2012 10:39 AM
FMX T-5 swap question irishn8 Classic Mustangs 7 02-13-2012 08:31 PM
question about foxbody 93_347foxbody 1979-1995 Mustang GT 2 02-11-2012 02:25 PM
09:22 PM
