95 gt 5.0 fuel pump ? - Mustang Evolution
Old 02-15-2012, 06:21 PM   #1
i have a 255 iph bbk fuel pump air flow system is pretty much stock except for bbk cai i noticed most people here have bbk 190 fuel pump i think this is making my car hic up is that possible because i think i have check everything else i need leads people help but answer my question first
durtyred69 is offline   Reply With Quote
Old 02-15-2012, 06:42 PM   #2
im not sure if it would cause your hiccup or not but it is pretty big.a 190 would be better suited for your needs.
Old 02-15-2012, 07:14 PM   #3
WhiteCobra94's Avatar
It doesn't matter if you have a 190 or 255 that's what your fuel pressure regulator is for, .... Your fuel pressure might have dropped, or dirty MAF!!!
Old 02-15-2012, 07:51 PM   #4
I do have adj fuel pressure reg. Maf is reman got it about 6mos ago with wat I stated in my email wat is best pressure to set it's at factory setting now I think
Old 02-15-2012, 09:01 PM   #5
Re: 95 gt 5.0 fuel pump ?
Fuel pressure should be set with the vacuum line to the regulator disconnected.Set it to 38 - 40 psi at idle.
Something I noticed once when changing out an in tank fuel pump:
On some, maybe all in tank pumps there is a small metal collar on the fuel pump discharge fitting where you connect it to the fuel line rubber hose.
Sometimes when removing the fuel pump, but not the hose, I noticed that the small metal cap can come off and remain inside the rubber hose.
As long as you change out the hose too, it will not cause any problems, but if you don't and that metal cap stays in the rubber hose when you install a new pump, it will disrupt your fuel flow and your engine may not get enough fuel from your new pump.
After discovering that issue, I always wondered how many times that may have happened to people causing unexplained problems with their cars.
Spark plugs for 06 GT Strick9 2005-2010 Mustang GT 40 02-20-2012 11:31 PM
rear main 89 5.0 jacob.a.gasparp 1979-1995 Mustang GT 20 02-18-2012 07:04 AM
supercharged GT spark plugs? ? victory181 1996-2004 Mustang GT 3 02-15-2012 06:50 PM
2012 GT automatic tranny leaking? meast553 2011-2014 Mustang GT 12 02-15-2012 09:12 AM
BBK Fuel Pressure Regulator Qs Boss707 1979-1995 Mustang GT 1 02-14-2012 08:15 PM
07:17 PM
