Convertible Top Prices?,. - Mustang Evolution
Old 02-17-2012, 05:00 PM   #1
MustangGT94's Avatar
How much would it cost to fix a sun burned and torn convertible top?,
MustangGT94 is offline   Reply With Quote
Old 02-17-2012, 05:08 PM   #2
5.slow's Avatar
Region: Delaware
I can't remember where I saw it but I think I remember seeing them as low as 160-200 bucks.
5.slow is offline   Reply With Quote
Old 02-17-2012, 05:36 PM   #3
I would check late model restoration. Once you meet a certain criteria you can get a futon member discount. I believe that is having 50 posts, but check out the sticky thread under support sponsors.the top itself is around 150 but the whole kit is in the 250-300 range.the whole kit may or may not be required.the kit comes with pads and stuff like that.what I would do is see what comes in the kit and check those pieces to see if they are bad.the pads go between the top and the frame.it is a pretty difficult process to install yourself, but it is doable as long as you take your time and follow the directions to a t.I would recommend buying the how to DVD.lrs has that also.if you pay to have it installed it could range from .400- 800. You have to check your local shops.
Old 02-17-2012, 05:42 PM   #4
Stang.racr's Avatar
From what I've heard on HERE is don't buy what from anybody that's not ford and try to take it to a ford dealership bodyshop cause they won't I stall it: but yeah you can buy a new top and a DVD and get some help replacing it as long as you got more patentice than I do lol
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 02-17-2012, 05:46 PM   #5
Originally Posted by 5.slow
i can't remember where i saw it but i think i remember seeing them as low as 160-200 bucks.
yeah i heard the same too, a company was trying to charge me $2,000
---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
GOOD POINT THANKS
Old 02-17-2012, 06:06 PM   #6
I had no problems with the one LRS sells.I believe its electon.if you do it yourself I sell recommended getting a power stapler.I can't remember the exact amount but it took me probably 500+ staples.and a normal manual stapler(even a good one) is not really strong enough.and watch the video all the way through,even twice before you start.also what I did was set up a tv and DVD player in the garage to refernce while I was installing.
Old 02-18-2012, 09:01 AM   #7
Re: Convertible Top Prices?,.
If you shop around you can probably find a good deal at a local upholstery shop if you don't feel comfortable doing the work yourself. I found a few shops down here that will do the top, with installation, for $800 on my 90.
Vinyl top advice Neds68Stang Classic Mustangs 9 03-07-2012 06:33 PM
New Season of Top Gear (American Version) sonicpony03 The Bar 7 02-15-2012 12:06 PM
Drop Top Panels?? Headhuntermma 2005-2010 V6 Mustang 9 02-14-2012 11:04 AM
1997 Explorer engine in 1989 convertible kbolden50 1979-1995 Mustang GT 7 02-14-2012 12:23 AM
11:55 AM
