What kind of cam is this - Mustang Evolution
Old 02-17-2012, 06:29 PM   #1
kbolden50's Avatar
Im trying to find out what kind of cams i have one i took out one from a 1989 mark vii and the other someone gave me and said it was a good cam and no other info on it the one out of the 89 had a z8 or 8z on it and the other one had a TE
ID:	41013   Click image for larger version
kbolden50 is offline   Reply With Quote
Old 02-17-2012, 06:56 PM   #2
Re: What kind of cam is this
Don't know from those numbers.Anything on the ends?
Old 02-17-2012, 11:11 PM   #3
kbolden50's Avatar
The 89 had 2111 dc the other didn't have marks but a little one that looked like 1and 7
ID:	41036   Click image for larger version
Old 02-18-2012, 12:07 AM   #4
Search turned up nothing for any of the numbers or letters you found.
I have to assume that those are just stock engine camshafts.
You can use this picture and measure the camshaft lobes to get an idea of lobe lift if you want.
Name:	Measure Cam Lobe Lift.jpg
Old 02-18-2012, 03:16 AM   #5
With the cam still in and heads off u could measure lobe lift.of possibly if u had a fixture or even Chuck it up in a lathe.u can use a dial indicator.you could also measure lobe seperation with the same process using a degree wheel.
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
What are you currently listening to? Brent The Bar 11215 09-07-2016 06:12 PM
Stalling after getting of Highway? righter86 2005-2010 Mustang GT 4 02-17-2012 06:19 PM
What should I get? vinnygt General Car Discussion 7 02-16-2012 11:15 PM
07:35 PM
