HELP!!!!! - Page 2 - Mustang Evolution
Old 02-25-2012, 10:04 PM   #36
jacob.a.gasparp's Avatar
Region: Nebraska
Now that sounds sexy. Like have the letter plate red or something?
jacob.a.gasparp is offline   Reply With Quote
Old 02-26-2012, 05:58 AM   #37
Re: HELP!!!!!
Yeah, the letters are raised on the Victor intake, but you get the idea.
Old 04-24-2012, 02:08 PM   #38
Region: Nebraska
Alright I am almost done putting everything back together soon. Hopefully will hear her start in the next couple of days
Old 04-24-2012, 08:09 PM   #39
Re: HELP!!!!!
Good luck.
Old 04-26-2012, 01:02 PM   #40
Region: Nebraska
So i have everything connected and when i went to start my car I heard that clicking from the starter that means only one thing. Time to change that battery lol and make sure the bolt on the starter is tight. Lol darn battery I was so excited to hear it run lol.
Old 04-29-2012, 09:28 AM   #41
Re: HELP!!!!!
I just read through and it sounds like you had the "typical" problems with a R-n-R. I was wondering a couple things though. 1, did you get a roller HO cam in there (or did you find the HO firing order was the correct order for your engine?) and 2, did you replace the battery and get it fired yet? If you replaced the cam, I hope you also replaced the lifters and even rockers at the same time. Makes a good difference impo.
Oh, and that pic in post 7 resembles an air injection(smog) pump crossover part. That allows for added air and thus, added o2 to enter your system allowing for better emission readings. When stock, there was almost certainly a pipe running from the rear of each cylinder head with that pictured piece on each head, connecting the pipe. It has also been called the thermactor pipe. Instead, yours may be solid and used as a block-off. You can probably still purchase the (5/8" I think) plugs from Ford if you don't wanna re-use that bolt, etc. They screw in flush and things look normal.
All41 is offline   Reply With Quote
Old 04-29-2012, 07:07 PM   #42
Region: Nebraska
Hey yall I charged the battery and it fired right up. Real loud though because I lost the four nuts that bolt the exhaust to their manifolds. Ran it for a little bit and noticed the seal where the drive shaft connects to the transmission is somewhat chewed up and leaks a little and the my brakes are extremely weak so I'm going to have my local mechanic fix my brake, exhaust, and seal problem for me. I don't have time to do it all right now since I just started working at a John deere dealership as a diesel tech. I can't wait to drive the stang to work I will be so excited and happy to have good fuel mileage again compared to my truck. all in all the car runs great and it is great be able to have the power of American muscle in my driveway again.
Oh i didn't have time to tear the engine apart because the farmer's shop I was using needed it back because planting season has begun.
Wheel spacers help! jamin22786 2005-2010 V6 Mustang 9 02-26-2012 06:32 PM
Dynomat help with drone? Jmoss 2011-2014 Mustang GT 5 02-18-2012 12:52 PM
exhaust help!? reeg2010 2011-2014 Mustang GT 28 02-18-2012 02:36 AM
Wheel decision, help me out! Brock23 2011-2014 Mustang GT 26 02-17-2012 01:09 AM
brakes squeaking help!!!!!! really annoying austinknoll Pre-2005 V6 Mustang 11 02-16-2012 09:31 PM
05:07 PM
