vibration troubles - Mustang Evolution
Old 02-19-2012, 08:18 AM   #1
hellonme's Avatar
vibration troubles
I've recently changed my clutch and had to remove the drive shaft to do so does that have to go back in in the same position it came off. Asking cause now I have a vibration from the back when accelerating but as soon as im let off the gas it's smooth till I press the gas again please help
hellonme is offline   Reply With Quote
Old 02-19-2012, 08:42 AM   #2
Taxman's Avatar
I did the same thing an I marked the shaft but didn't put it back in the same position, I dont have that problem though... Did you change the u joints? An are you sure your pressure plate is on correctly? Bc if it not it could be engaging on part of it, does it vibrate when coasting an the clutch is fully engaged?
---------- Post added at 09:42 AM ---------- Previous post was at 09:41 AM ----------
I ment to say is your clutch disk on correctly* centered with the pressure plate*
Taxman is offline   Reply With Quote
Old 02-19-2012, 08:46 AM   #3
hellonme's Avatar
I've always been told put the drive shaft on the same way it came off lol I forgot yes everything is lined up good . When I let off the gas whether the car is in gear or in neutral coasting its like riding on a cloud lol soon as I hit the gas its vibration city and now didn't change the universals
Old 02-19-2012, 08:50 AM   #4
Taxman's Avatar
Did you change the flywheel? Or have it resurfaced? If I had to guess it's that or the I joints... For the price an labor I'd do the joints first...
Old 02-19-2012, 08:52 AM   #5
jhagan1980's Avatar
It's highly recommended that it goes back on in same position.
jhagan1980 is offline   Reply With Quote
Old 02-19-2012, 08:52 AM   #6
hellonme's Avatar
Not the flywheel adult yn bad spots or heat cracks yeah ill try moving the drive shaft then universal thx for the help
Old 02-19-2012, 08:54 AM   #7
Taxman's Avatar
Huh? Lol
Old 02-19-2012, 08:54 AM   #8
hellonme's Avatar
Stupid phone flywheel didn't have any cracks or bad spots lol
Old 02-19-2012, 11:03 AM   #9
jhagan1980's Avatar
Still should've had it resurfaced.
Old 02-19-2012, 09:41 PM   #10
Re: vibration troubles
You always have to put it back in the same position or it is likely to vibrate.
Driveshafts are phased from the factory to prevent vibrations.
Always, resurface your flywheel if you reuse it to ensure it is flat and to remove any glazing on the surface, otherwise your clutch may chatter and vibrate when engaging it and your new clutch will not last as long.
Steering vibration/shimmy Aggiesrok 2005-2010 Mustang GT 5 01-19-2012 08:50 PM
High speed vibration Weeg15 General Mustang Discussion 11 11-06-2011 07:50 AM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
Vibration at 72 cono12 Pre-2005 V6 Mustang 3 08-13-2011 06:46 AM
Bad vibration/rattle under the accelerator? austin101385 2011-2014 Mustang GT 14 06-04-2011 10:39 AM
09:46 PM
