Trick flow 170 heads - Mustang Evolution
Old 02-19-2012, 04:42 PM   #1
04machazblue's Avatar
Was considering swapping trick flow tw heads what components would have to be changed to use them
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 02-19-2012, 05:01 PM   #2
i am carbed, but i am in the middle of the swap as we speak.you will need pushrods and gaskets at minumum.if you look up parts on summit racing you can usually get the instructions.http://www.summitracing.com/parts/TFS-51400002/?rtype=1
Old 02-19-2012, 05:08 PM   #3
WhiteCobra94's Avatar
Are they studded mounted heads, if so you'll need stud mounts and new rocker arms , (only if your old heads are pedestal mount)
Old 02-19-2012, 05:11 PM   #4
yes they are stud mount.they come with the studs and guide plates.i added the 1.72 rr to mine
Old 02-19-2012, 05:26 PM   #5
Ok good , what intake and cam do you have ? MAF and injectors?
Old 02-19-2012, 05:29 PM   #6
no injectors or maf.but 670 holley,weiand stealth intake,b303 with the 1.72s that puts my lift at .516 . i checked piston to valve clearance and put alot of clay on the piston and it never evn touched.so i have plenty of room.
Old 02-19-2012, 05:40 PM   #7
I believe the gt40x have the stud mounted rockers and there 1.6 ford racing ones
Old 02-19-2012, 06:07 PM   #8
the heads won come with rockers.you will have to chose what u want in there.what white is saying that some heads are stud mount and some are pedestal.if you current setup is already stud mount then you can reuse them.if they are pedestal mount then you will have to buy new rockers to run the trickflow.
Old 02-21-2012, 08:42 AM   #9
Also there are two options on American muscle for the twisted wedge heads the one has .540 with single spring
Max lift and the other is .600 with dual spring there is a 100$ dollar difference
Old 02-21-2012, 08:49 PM   #10
theStangMan's Avatar
Re: Trick flow 170 heads
Nice choice of heads.I have a set on my 396 stroker Bricklin.
Chris "the Doc" Ingrassia
Mustang Restoration, Inc. - Shop Owner
www.OperationMustang.com Free Web Show - Host
www.facebook.com/OperationMustang - LIKE the Show
www.Youtube.com/CutUpMan2 - Free How-To Videos
MustangRestoration@Hotmail.com
theStangMan is offline   Reply With Quote
Old 02-21-2012, 08:59 PM   #11
agreed,i just finished installing mine yesterday.
---------- Post added at 09:55 PM ---------- Previous post was at 09:52 PM ----------
i talked to trickflow and he said the only difference was the valve springs.the better springs im assuming what allows for more lift.im not sure why but i ordered the cheaper set and mine came with double valve springs i remember reading exactly what u said about the cheaper ones having single springs.
---------- Post added at 09:59 PM ---------- Previous post was at 09:55 PM ----------
unless that was just spring retainers i was looking at,but i didnt pay much attention
Old 02-22-2012, 06:31 AM   #12
The only things I can see that you would need to swap the heads would be 6.700" pushrods and your gaskets. That is if you are just swapping the heads on the combination you have listed in your sig.
Gregg@TFS is offline   Reply With Quote
Old 02-22-2012, 08:59 AM   #13
Just swapping heads Idk I am considering a few think like changing my cam and intake and keep the heads but I am trying to find a flow chart to compare the two head my currents ones gt40x to the trick flows and If it's worth spending the 1300$
Old 02-22-2012, 09:09 AM   #14
Lift Value Intake Flow CFM Exhaust Flow CFM
0.100" 63 53
0.200" 141 107
0.300" 205 144
0.400" 233 171
0.500" 251 187
0.600" 251 193
Tests conducted at 28" of water (pressure). Bore size: 4.030"
61cc CNC-profiled combustion chambers; exhaust with 13⁄4" pipe.
Very worth it over the GT40's.
Old 02-22-2012, 09:20 AM   #15
Yea gt40x's "claim" 240" at .600 lift intake side
---------- Post added at 11:20 AM ---------- Previous post was at 11:20 AM ----------
My friends got same heads track heat for sale I can prolly get for 800$
Old 02-22-2012, 09:22 AM   #16
stampde's Avatar
he has gt40x turbo swirl heads
and in my opinion ,its NOT WORTH $ 1300
He will probably pick up 10-15 HP using the same cam and intake
but with the Gt40x heads he can use a bigger cam without changing pistons ,but with the Trickflow's there is a limit on the cam without changing pistons
I've been there done that with the Trick Flows , I know all about them ,they are great heads , but your limited on cam choices ................. i know he doesn't wan't to go into the bottom end on his engine
2011 GT Auto
Old 02-22-2012, 09:36 AM   #17
The TW head is 20 better than the X head, not to mention he would be getting a cylinder head he can grow into.
Old 02-22-2012, 10:01 AM   #18
In the sticky section under useful mustang info there are some flow charts for most heads.
Old 02-22-2012, 02:50 PM   #19
What I am not impressed with trickflow is the little tiny sticker that came with my heads.
Old 02-22-2012, 02:52 PM   #20
Pm me your address and I will get you some decals out.
Old 02-22-2012, 02:53 PM   #21
Sweet! Thanx
New heads Rm360 1996-2004 Mustang GT 16 02-23-2012 11:28 AM
00 Continental Heads 32vNomad 1996-2004 Mustang GT 1 02-16-2012 12:24 AM
351 Heads 89Saleen141 1979-1995 Mustang GT 4 02-15-2012 07:12 PM
Roush 200 heads 91coupe 1979-1995 Mustang GT 6 02-06-2012 02:04 PM
speed density vs mass air flow Giles85 1979-1995 Mustang GT 4 02-03-2012 06:30 AM
04:05 AM
