Mozzler replacement - Mustang Evolution
Old 02-20-2012, 04:44 AM   #1
Coryshade1995's Avatar
Mozzler replacement
DOes anyone know how hard a mozzler would be to replace in my c4?I wanna do it myself to save money but I'd like to know if it's something I can do on my own
Coryshade1995 is offline   Reply With Quote
Old 02-20-2012, 07:48 AM   #2
Re: Mozzler replacement
I never heard of a mozzler?
What is it?
Old 02-20-2012, 02:29 PM   #3
It's in the transmission and for some reason mines bad because it doesn't hold transmission fluid for more then a day.and I'll look under the car and there's no puddle of fluid
Old 02-20-2012, 03:08 PM   #4
Cobrarunnin9s's Avatar
Whoever told you there was a mozzler in a transmission is an idiot. It's probably your vacuum modulator which is on the side of your transmission case.
Cobrarunnin9s is offline   Reply With Quote
Old 02-20-2012, 04:45 PM   #5
He's right it is a vacuum modulator.
If they go bad sometimes the diaphragm ruptures and then your engine vacuum will draw fluid out of the transmission into the engine intake where it will eventually be conveyed into the cylinders and burned.
You can pull the vacuum hose off of the modulator to see if it has transmission fluid in it.
If I remember correctly it is pretty easy to change, there is one bolt holding a clamp that holds the modulator in place. If there is a steel rod in the modulator when you remove it, it may need to be removed and placed in the new one.
Read the instructions or buy a manual explaining how it should be done.
Trunk lid GT badge replacement Delta vt 2011-2014 Mustang GT 30 03-24-2012 04:36 PM
Heater core replacement OG86GT 1979-1995 Mustang GT 6 02-08-2012 10:28 AM
Torque box replacement LX5011 1979-1995 Mustang GT 12 01-08-2012 07:52 PM
My Side Mirror Broke Off and Now I Need Advice Regarding Replacement JimHyde 1996-2004 Mustang GT 3 12-03-2011 08:16 PM
05:36 PM
