Need help!!!! - Mustang Evolution
Old 02-21-2012, 04:32 AM   #1
WhiteCobra94's Avatar
Need help!!!!
Hey guys I have a problem my elbow adaptor turns right towards my valve cover oil fill, has anyone had this problem and knows how to fix or modify?
Old 02-21-2012, 08:27 AM   #2
88gtCc's Avatar
I would suggest maybe a Phenolic (or however its spelled) Spacer. That should move the elbow up and hopefully give you enough room to clear that. Other than that...I got nothing :/
88gtCc is offline   Reply With Quote
Old 02-21-2012, 08:36 AM   #3
Yea that will clear it but now it's still aiming at the oil filler, but my stock valve covers are fine......
Old 02-21-2012, 04:48 PM   #4
Re: Need help!!!!
Is using a spacer between the elbow and intake possible? (Some intakes have the elbow cast into them.)
If not you will need a flat cap and just have to deal with it or try to move the fill cap to the back of that valve cover or to the other side valve cover.
Old 02-21-2012, 08:59 PM   #5
I thought about putting a 1 inch throttle body spacer between my elbow and intake i don't know if that could be a fix or not
Old 02-21-2012, 09:18 PM   #6
Or different valve covers maybe?my oil filler on the passenger valve cover is closer to the firewall.
Old 02-21-2012, 10:37 PM   #7
Re: Need help!!!!
As long as it will clear the strut tower and 1" will let it clear the oil fill cap it should work.
Take it loose and hold it out 1" and see if it will clear.
Or if you have room at the rear of the engine on the other side of the engine, you could swap the valve covers.
HELP!!!!! jacob.a.gasparp 1979-1995 Mustang GT 41 04-29-2012 07:07 PM
Tuner help 2002VertGT 1996-2004 Mustang GT 43 02-28-2012 07:16 PM
New wheels help Jzelm10 1979-1995 Mustang GT 8 02-21-2012 07:26 AM
gauge lights help!! murraydylan1993 1996-2004 Mustang GT 3 02-20-2012 10:05 PM
I need help finding wheels! Jzelm10 Mustang Wheels & Tires 0 02-20-2012 07:47 PM
03:03 AM
