Junkyard Part List - Mustang Evolution
Old 02-23-2012, 10:13 AM   #1
88gtCc's Avatar
Junkyard Part List
Hey guys! My friend just picked up a foxbody just like mine (88 gt). We were curious as to what parts could be upgraded from other cars. I know Ive seen that the gt-40 intake is off some year explorer and 24lbs injectors can be found on a diff vehicle. Can anyone specify which years and models exactly; and is there anything else that could be upgraded? Thanks!!
88gtCc is offline   Reply With Quote
Old 02-23-2012, 10:21 AM   #2
Re: Junkyard Part List
Suspension, 5-lug conversion and brakes from the SN95's.
Old 02-23-2012, 10:52 AM   #3
93slowstang's Avatar
Most of the 4.6 v8 trucks use 24lb injectors. You can use the front spindles off any 94-98 mustang (v6 or gt, they are the same). Maf housing can be used off the sn95 if you keep the 19lb injectors.
Old 02-23-2012, 11:25 AM   #4
88gtCc's Avatar
Thanks for the quick replies! Slow, do you happen to know which trucks by chance? Or is there a way I could determine their 24lbs by looking at them? Not too sure on the gt40 intake still. Some year explorer? Are there any gt40 heads that came stock on a car (other than cobras of course lol)?
Old 02-23-2012, 11:35 AM   #5
5.slow's Avatar
Region: Delaware
V8 explorers and mountaineers until 2001 had either gt40 or gt40p heads.
5.slow is offline   Reply With Quote
Old 02-23-2012, 11:51 AM   #6
88gtCc's Avatar
Good to know The gt40p's require new plug wires correct? Something about weird angles and the headers? Can I assume that the intake would also be the gt-40 if it has the gt-40 heads?
Old 02-23-2012, 11:52 AM   #7
I recently read that the SN95 MAF is bigger at 70MM, but the backflow inhibitor inside it reduces the flow to little more than a 55MM, so it isn't really any better than the stock Fox Body MAF meters.
Old 02-23-2012, 11:40 PM   #8
Doesn't look like it inhibits it too much to me, but heres a side by side for comparison.
Old 02-23-2012, 11:50 PM   #9
If you get the "p" specific headers plug wire selection won't be a problem. The spark plug angles were almost straight out instead of angled for better combustion.
96-01 explorers and 97-01 mountaineers had the gt40 intake. 96- early 97 explorers had gt40 heads and from late 97-01 they switched to gt40p. All v8 mountaineers from 97-01 had gt40p heads.
Old 02-24-2012, 12:23 AM   #10
Doesn't look like it if that's it on the right, but that's what the Ford Performance book I have says.
Old 02-24-2012, 01:25 AM   #11
Here's a quick reference for ya, I believe it's somewhere in the stickies too. I'm not certain on which specific years but the chart will at least give you a visual aide.
Old 02-24-2012, 10:30 PM   #12
CatchMe's Avatar
Any suggestions as to how to route the clutch cable on an 89 5.0
CatchMe is offline   Reply With Quote
Post Your Ink - Part II Lalayla Pictures and Videos 335 08-24-2013 03:51 PM
my mod list questions imhooked 1996-2004 Mustang GT 22 02-19-2012 01:07 PM
Craigs list advise captain78 1979-1995 Mustang GT 4 02-14-2012 03:19 PM
new part on the car Always broke 2005-2010 Mustang GT 0 02-01-2012 09:59 AM
06:05 PM
