74 351w block - Mustang Evolution
Old 02-23-2012, 12:15 PM   #1
Redsteel's Avatar
74 351w block
I found a 74 351w block bored .0040 over. I'm not sure if this is safe to use. I know it already has the roller cam swap done and I'd love to get it because its cheap. Any help?
Redsteel is offline   Reply With Quote
Old 02-23-2012, 12:21 PM   #2
1995boss's Avatar
I got a whole book on working with these babies. What's your concern?
1995boss is offline   Reply With Quote
Old 02-23-2012, 01:36 PM   #3
Redsteel's Avatar
Is a 40 over bore too much to mess with?
Old 02-23-2012, 02:01 PM   #4
1995boss's Avatar
Are you wanting to counter at the bore? For example
You can have a standards bore 4.000 inch bore and overbore it by .030-inch to 4.030 inch, compression will increase by a fraction of a compression ratio point.
You can make a pretty nasty stroker with a 351 Windsor.
Old 02-23-2012, 02:41 PM   #5
stampde's Avatar
Re: 74 351w block
or just throw a set of 40 over pistons in it ,think that makes it a 357 ci
and be on your way ...
2011 GT Auto
Old 02-23-2012, 03:11 PM   #6
1995boss's Avatar
I think it's a 359ci with a 3.50 stroke
Old 02-23-2012, 08:27 PM   #7
Re: 74 351w block
.040 oversize bore is .010 past what the factory recommends for a stock 351W oversize bore.
However if the block experienced minimal or no core shift when it was cast then it should be ok.
Core shift can be "eyeball evaluated" by observing how well the freeze plug holes in the sides of the block are centered in the bosses cast for them. As long as they are pretty much centered, I wouldn't be overly concerned about the .040 over bore.
Just be sure the bore is square and the finish is correct as you don't have much room left for any corrective machine work.
P.S. I have tried up to a .060 bore in a SBF that exhibited no external evidence of core shift, but that left me with an engine that easily overheated due to the very thin cylinder walls and I doubt it could have withstood much abuse without disintegrating under the pressure. Driven granny style in an old Mercury Marquis, it did survive for just over another 150k miles though.
Old 02-23-2012, 08:29 PM   #8
1995boss's Avatar
Well put my friend. ^ damn traveling Wikipedia here haha
Old 02-23-2012, 09:01 PM   #9
Re: 74 351w block
Thanks.
I read and surf the net voraciously, devouring any automotive information that interests me.
Luckily, I'm even able to retain some of it to share with my friends.
Old 02-23-2012, 09:07 PM   #10
1995boss's Avatar
Thanks.
Haha I know I can see that. I feel like your Yoda.
Old 02-23-2012, 09:23 PM   #11
Re: 74 351w block
Hmmm, funny, that is.
I'm not quite that wrinkled or short though and I don't have large pointy ears.
Old 02-23-2012, 09:26 PM   #12
1995boss's Avatar
Hardy har har smartass! Literally haha. I think you would like the book I got. It's call " how to build big inch ford small blocks" but you prolly wouldn't need it by know the bore of that 351w off hand.
Old 02-23-2012, 09:27 PM   #13
i bet he has the book!
Old 02-23-2012, 09:29 PM   #14
1995boss's Avatar
Shoot I would doubt it. I'm only 20 and its always by my chair and I still could tell you bore right off my head. Maybe stroke haha (big stroker guy) no homo
Old 02-23-2012, 09:34 PM   #15
i have no book and i do know my bore is 4.030 "and i think my stroke is 3". and dont say but i know its a small stroke.
---------- Post added at 10:34 PM ---------- Previous post was at 10:32 PM ----------
no seriously i purchased the book supertuning holleys that trojan recommended and it is very informative.that is my bathroom reading material.
Old 02-23-2012, 09:48 PM   #16
Re: 74 351w block
I actually think I may have a old version of it out in my garage.
At the moment I have 7 different Chilton's and Ford Performance books right here by my PC. Not sure exactly how many more in the garage, but there are several.
Old 02-23-2012, 09:52 PM   #17
i knew you liked to read so i figured u did.
Old 02-24-2012, 09:17 AM   #18
Redsteel's Avatar
So if everythings good and straight in 2 weeks I should have the start of a nasty 351w to throw in Red Steel and Sex Appeal
302 block Robbie94gt 1979-1995 Mustang GT 14 02-22-2012 05:15 AM
460bbf or 351w Stockish302 1979-1995 Mustang GT 10 01-25-2012 02:55 AM
1973 mach 1 351w -> 1983 gt 351Stang 1979-1995 Mustang GT 3 01-23-2012 11:51 AM
351W or 351C Elfman 1979-1995 Mustang GT 4 01-20-2012 04:20 PM
Big block V6_roller General Car Discussion 1 01-17-2012 09:45 PM
11:31 AM
