wont start - Mustang Evolution
Old 12-03-2007, 01:54 AM   #1
Red face wont start
94, 302 running really rough, rebuilt the transmission (screwed for $1743.00),replaced distributor and it ran beatifully for about 6 hrs then it sounded like it flooded out when i was diving down the road. it would not restart. it has gas, i've checked the air valve on the passenger side fuel rail, replaced the coil, plugs, and wires but it still is not getting spark. any suggestions would be great. i'm tired of dunping money into this money pit.
joezappitella is offline   Reply With Quote
Old 12-03-2007, 09:59 AM   #2
MonteCitan's Avatar
Re: wont start
When you checked the valve on the fuel rail, did any fuel spray out? there ought to have been sufficient pressure, and plenty of fuel there, no air should have come out...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-03-2007, 11:17 AM   #3
Re: wont start
yeah fuel sprayed out not air. someone told me it could be the ignition module but were is it, its not on the distributor
Old 12-03-2007, 11:31 AM   #4
MonteCitan's Avatar
Re: wont start
There is a module on the distributor that tends to fail, and often with the same symptoms you're having -- http://www.coolcats.net/tech/trouble...mages/tfi1.jpg
Something simple to try, unplug your mass air sensor (right after the airbox or filter, in case...) then try to start the car...
Old 12-04-2007, 01:41 PM   #5
Re: wont start
its the pickup in the distributor. i replaced it and the car is now back firing, i don't know how to set the timing
Old 12-04-2007, 08:17 PM   #6
MonteCitan's Avatar
Re: wont start
Without a timing light, a quick fix would be to loosen the one bolt holding the distributor in place, and rotate the distributor til the car stops backfiring, then go a little further and bolt it down, take it for a spin, if it pings, rotate a little further...
Help It Wont Start... kack85 Pre-2005 V6 Mustang 5 07-28-2009 07:14 AM
wont start !!! too fast Pre-2005 V6 Mustang 7 04-24-2009 07:26 AM
wont start...new tranny 1989mustang306 1979-1995 Mustang GT 4 06-02-2008 06:36 AM
Car wont start iwannagofast 1996-2004 Mustang GT 3 03-03-2008 09:34 PM
wont start???? bluestang1724 1979-1995 Mustang GT 11 01-04-2008 09:10 AM
05:06 PM
