Oil pressure guage - Mustang Evolution
Old 02-24-2012, 08:36 AM   #1
Taxman's Avatar
Oil pressure guage
IM either not getting oil pressure or my gauge is bad it seems to drop when the engine warms up... Any ideas?
Taxman is offline   Reply With Quote
Old 02-24-2012, 08:43 AM   #2
Willie's Avatar
Region: West Virgina
I'd say pump is bad
Willie is offline   Reply With Quote
Old 02-24-2012, 11:18 AM   #3
Taxman's Avatar
Originally Posted by Willie
I'd say pump is bad
How hard is that to change
Old 02-24-2012, 11:25 AM   #4
deadsp0t's Avatar
The entire engine has to be lifted enough to remove the oil pan. I would get an aftermarket gauge to test before I went to replacing the pump.
That's unimpressive
Old 02-24-2012, 12:37 PM   #5
Taxman's Avatar
Is the pressure measured before or after the oil filter
Old 02-24-2012, 02:50 PM   #6
There should be a sending unit for the stock gauge and put your new gauge there.I think its on the driver side toward the front of the motor.I could be wrong though
Old 02-24-2012, 03:00 PM   #7
Taxman's Avatar
10-4 thanks
Old 02-24-2012, 03:12 PM   #8
captain78's Avatar
Yea driver side front right behind timing cover. If you losing pressure completely while you have oil pan down to check pump check your bearings as well. When that happened to me. I checked my bearings only after I bought new oil pump and come to find out every bearing in the motor was shot. Easy tell tell if bearings are shot is when you drain your oil check for any metal flakes in oil. But that doesnt alway say for sure. Until you check
captain78 is offline   Reply With Quote
Old 02-24-2012, 03:31 PM   #9
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Never trust the factory oil gauge. Grab a mechanical one from advanced which is around 20 bucks I think, that will tell you exactly what psi your running at.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-24-2012, 03:44 PM   #10
Taxman's Avatar
Thanks guys hopefully it's my guage I'm wanna ride I wanna ride I wanna ride lol
Old 02-24-2012, 08:00 PM   #11
Re: Oil pressure guage
When the oil pressure drops as the engine warms up it is usually a sign of worn bearings.The farther it drops the worse the wear is.
I have seen engines with bearings so worn out that the oil pressure would drop to zero at a stop light when the engine was at operating temperature.
If your pressure climbs when the RPMs increase, then it is likely that your oil pump is ok and worn bearings are the issue.
Old 02-24-2012, 08:13 PM   #12
Taxman's Avatar
It doesn't climb when the rpms are raised.. Sob!! Lol
Old 02-24-2012, 08:17 PM   #13
06Ghost's Avatar
Check the sendin unit first but when was last oil change
06Ghost is offline   Reply With Quote
Old 02-24-2012, 08:24 PM   #14
Taxman's Avatar
Imma check that first, last oilchange was about 2500 miles ago... Looks like I'll be poppin tops an turning wrenches again....
Old 02-24-2012, 08:25 PM   #15
Like the guys have said get a mechanical gauge and check it first as the stock electrical gauge and sending unit may be the culprit. Fingers crossed.
Old 02-24-2012, 08:27 PM   #16
not sure if thats the problem but an easy cheap place to start.
black carbon in throttle body? oil smell? Mweigt07 2011-2014 Mustang GT 15 02-25-2012 10:06 PM
Lost oil pressure Bigb 1979-1995 Mustang GT 31 02-25-2012 07:06 PM
Got my Fuel Pressure Regulator today!! Mustang_Madness 1996-2004 Mustang GT 0 02-23-2012 01:12 PM
Oil Consumption Ravnus 2011-2014 Mustang GT 7 02-21-2012 06:26 AM
Oil Leak. Like, A lot of it. Mustang_Madness 1996-2004 Mustang GT 16 02-19-2012 01:27 PM
08:13 PM
