transmission help - Mustang Evolution
Old 02-25-2012, 10:38 AM   #1
hellonme's Avatar
transmission help
I have a t5 out of a 91 lx 5.0 its bad locked up I have a newer transmission out of a 94 4.? Liter the input shafts are different can I put my 91 input shaft into the 94
hellonme is offline   Reply With Quote
Old 02-25-2012, 06:38 PM   #2
You may have better luck in the 79-95 section.
I'm not sure on that model but some people use the 2.3 t5 with different input shafts and just change the pilot bearing.
Old 02-25-2012, 07:15 PM   #3
deadsp0t's Avatar
I've herd ppl say the 99 and up input shafts are the same as the 5.0 T5, never herd anything about the 94-98 3.8 T5's though.
If in fact they are not the same you'll need a pilot bearing that will mate the two. I've witnessed a mild 5.0L fox twist a D/S using a 4cyl T5 7.5 rear on slicks, so have no fear. I will move this to the 79-95 GT section so maybe you can get the correct info on the tranny and pilot bearing.
That's unimpressive
Old 02-25-2012, 07:37 PM   #4
Re: transmission help
The V6 and I4 model T-5 transmissions are weak and not really worth the effort of installing them.
Tear your T-5 apart and see how badly it is damaged. It may be rebuildable.
Old 02-25-2012, 07:45 PM   #5
deadsp0t's Avatar
This is true, but have seen several get guys by until proper replacement can be found, I will say the ones I've seen we're done by guys working at True Blue, now known as FastLane meaning they had access to lifts, tools and exp.
That's unimpressive
Racing chip help!! BeasGT 1996-2004 Mustang GT 6 02-27-2012 07:32 PM
SCT tuner owners help me out! Project Pony Pre-2005 V6 Mustang 25 02-25-2012 11:45 PM
Need help choppa5307 1979-1995 Mustang GT 4 02-25-2012 07:20 PM
Clutch help!!!!! CatchMe 1979-1995 Mustang GT 14 02-25-2012 12:07 PM
Help? Nog51 Pre-2005 V6 Mustang 6 02-24-2012 09:10 PM
» Members Mustangs
Trudy
Torino
2011 GT
Saxman
Add your Mustang
02:20 PM
