Clutch Pedal Problem - Mustang Evolution
Old 02-25-2012, 12:53 PM   #1
89Saleen141's Avatar
I was driving along on and my foot slipped off of the clutch while I was shifting gears and it kinda made a snapping sound and now the friction point to engage the clutch as almost at the floor. I don't know what could've happened. It looks like some kind of clip broke or something.
89Saleen141 is offline   Reply With Quote
Old 02-25-2012, 12:55 PM   #2
deadsp0t's Avatar
Have you replaced the plastic quadrant with an aluminum one? Also it may be the cable all but broken.
That's unimpressive
Old 02-25-2012, 01:08 PM   #3
Re: Clutch Pedal Problem
I haven't replaced the plastic quadrant yet. It'll still drive fine, its just that the clutch engages pretty much at the floor.
Old 02-25-2012, 07:26 PM   #4
Use your toes and lift up on the pedal as far as it will go and listen for some clicks.
It may have just lost its adjustment.
Old 02-26-2012, 01:16 PM   #5
Alrite, I'll try that out thanks. Quick question though, if I like the friction point closer to the ground, should I buy an adjustable clutch cable kit?
Old 02-26-2012, 01:27 PM   #6
Csnow99gt's Avatar
First check cable, but sounds like it could be your throwout bearing
Csnow99gt is offline   Reply With Quote
Old 02-26-2012, 06:00 PM   #7
it can be adjuated to where you like it but the best place to adjust it to is where it has maximun holding strength.you want to make sure its not slipping and the throw out bearing is not riding on the pressure plate all the time.
Old 02-26-2012, 06:05 PM   #8
Filibuster
When my cable snapped it did the same thing(clutch engaging at the floor)but my pedal also dropped almost to the floor because of the slack...so id think if its a cable you could tell by just that..
XXSTEVEO66 is offline   Reply With Quote
Old 02-26-2012, 08:29 PM   #9
Yeah, my pedal dropped really low also. I guess this gives me an excuse for getting an adjustable clutch cable kit.
---------- Post added at 09:29 PM ---------- Previous post was at 09:25 PM ----------
[QUOTE=dreamstang;1066696]it can be adjuated to where you like it but the best place to adjust it to is where it has maximun holding strength.you want to make sure its not slipping and the throw out bearing is not riding on the pressure plate all the time.[/QUOTE
Where would that be?
Old 02-26-2012, 08:29 PM   #10
deadsp0t's Avatar
Yup! Remove the dust shield on the driver side of the tranny(you'll see the cable going in) and you can see where the cable attaches to the shift fork, you'll see the damage there or above the pedals over towards the brake and gas pedal.
That's unimpressive
Old 02-26-2012, 08:34 PM   #11
you will be able to tell where it feel like it shifts firmest.you should be able to see inside the bell housing to make sure the bearing isnt on the pressure plate through the same area dead mentioned.
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
usually u will have 1/2-1" of play in the top off the pedal when adjusted properly unless your clutch is really worn
Old 02-26-2012, 08:55 PM   #12
Thanks guys, really helpful. I have the car stored away for one more week, I'll order the stuff and then post pics of the procedure.
Cleaned tb/plunum/maf now have problem 02PONY 1996-2004 Mustang GT 5 02-26-2012 08:33 PM
Clutch help!!!!! CatchMe 1979-1995 Mustang GT 14 02-25-2012 12:07 PM
Srod clutch 83 Fox 1979-1995 Mustang GT 1 02-23-2012 06:29 AM
clutch br10301 1996-2004 Mustang GT 10 02-22-2012 01:54 PM
Does anybody know how to shift without using the clutch? SwatKatz901 1996-2004 Mustang GT 12 02-20-2012 12:36 AM
02:34 AM
