injectors and intake question. - Mustang Evolution
Old 02-25-2012, 12:56 PM   #1
robert3188's Avatar
Bought a gt40 intake upper and lower it came with injectors with 4 little holes in the end not just 1 like my current ones. Should I use these or stick with the factory ones? Also there is a plug that has to be drilled out in the lower correct? One website said I could just lay that sensor in the valley of the intake....
robert3188 is offline   Reply With Quote
Old 02-25-2012, 03:27 PM   #2
93slowstang's Avatar
For that sensor to read correctly you need to drill and tap the boss for it. Some people run it to the intake right after the maf. I laid my in the valley and it's fine but I got lazy near the end of my h/c/I swap, otherwise I would have moved it or drilled the boss.
Old 02-25-2012, 05:15 PM   #3
robert3188's Avatar
Sweet. Whatu think bout them injectors?
Old 02-25-2012, 08:03 PM   #4
As long as the plug is the same they should work fine. The four holes give a better spray pattern.
New Mustang and new member Snowned 2011-2014 V6 Mustang 12 03-02-2012 09:43 PM
Cold Air Intake 03fastblack 1996-2004 Mustang GT 33 02-26-2012 01:27 AM
Just got intake Venomouz831 Pre-2005 V6 Mustang 33 02-25-2012 07:45 PM
All 4 Factory Cats With X-pipe and Flowmasters Memphis_Cound 1996-2004 Mustang GT 14 02-25-2012 08:52 AM
Intake Manifold Mustang_Madness 1996-2004 Mustang GT 8 02-25-2012 07:20 AM
03:43 PM
