You could do other mods that would be more efficient. When you start messing with cams on a older fox that didn't have mass air it can be a little head ach. Gt40 heads are a decent upgrade. They flow better than the e7 heads that are on your car now. If money isn't a problem I would spend the extra change on some aluminum heads
Yea I was looking at either the edelbrock performer, or the fordracing Gt40 heads, but I'm acually pretty good with electrical and wiring in the cars and have no problem wiring up a new MAF circuit with a new pcm. but I'm not sure about the heads yet, its kind of a huge hit to the pocket, I have about 2500 to spend for the build set aside, but do you think spnding 1000$ on heads is the best upgrade combo along with a cam?
Stock cam REALLY isn't that bad at all. Heads and an intake will net better gains than a cam swap alone. OBVIOUSLY if you can swing a comlete top end kit h/c/i combo will put the biggest smile on your face
Upgrade to MAF first. Speed Density will not respond well to any modifications that increase the engine's air flow by very much.
Buying a HCI kit will serve you much better as all of the parts are designed by experts to work together.
The Trick Flow HCI kits can provide as much as 360 HP, depending upon the kit you choose.
Or the GT40X heads coupled with the GT40 intake and an E303 cam can net you around 300 HP.
Sorry yes, upgrade to MAF first.... The GT40 combo is a nice budget build forsure, me personally would do a TFS stage 1 cam over the E-cam but again thats all personal preference.:headbang:
2500 should be able to do a full hci upgrade with a little bargain shopping.you can pick up the gt40s off of 96-01 explorer and also use there intake.you can probably score both of those for under 500$.spend about 50$ at local machine shop to get them dipped/cleaned.then get a cam,throttle body,24 lb injectors and matching maf,and exhaust.
Then take your girl out to a nice dinner cause if you do it right u may still have some money left.
Sounds like what I'm collecting parts for. I'm keeping the Ho cam for now. I'm waiting for my pro_m mass air meter to come in. Then I just need misc parts like gaskets and spacers and such. Hopefully I can get started in a few weeks.
the ho cam is good for 400 hp if the heads and intake can feed it!
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
