Originally Posted by 5.slow Just noticed that one of the heads that I got has a broken intake bolt stuck in it. Can a machine shop get one of those out pretty easy or am I in for a problem? |
IF, there is any sticking up, you can weld a nut on them. The heat also will serve to help break them loose.
A good "chemical" based penetrant sprayed on them several times a day for a couple of days will allow it time to get down into the threads and loosen them up.
If you drill them out, look for a small set of reverse twist drill bits. You run the drill in reverse to drill out the broken bolt and sometimes they will loosen and the bit will catch and spin them out.
If all else fails, just beat the head with a BFH (
Big ******* Hammer) until your anger is gone, then go get a different head.
