Copper header gaskets - Mustang Evolution
Old 02-26-2012, 02:59 PM   #1
Meansaleen's Avatar
After going thru 2 sets of fel-pro I decided to switch to copper ones. Any pros/cons to the copper gaskets? Also any special precautions I should take when installing them? Thanks
Meansaleen is offline   Reply With Quote
Old 02-26-2012, 08:33 PM   #2
WhiteCobra94's Avatar
How fast did you blew through the 2 sets?
Old 02-26-2012, 08:43 PM   #3
Meansaleen's Avatar
A little less than a year apart.
Old 02-26-2012, 10:00 PM   #4
five_0_85stang's Avatar
I have copper on my 302 never had an issue an I used self locking header bolts work amazing and no exhaust tick what so ever..good luck..nice Fox by the way
five_0_85stang is offline   Reply With Quote
Old 02-26-2012, 11:34 PM   #5
Re: Copper header gaskets
Spray them with some Permatex copper coat and pray.
I never had much luck with them unless the block had been o-ringed.
It has a lot to do with how well your head and deck surface are finished and how flat and true they are.
The MLS (Multi-Layer Steel) head gaskets may have been a better choice.
Old 02-27-2012, 05:21 AM   #6
Meansaleen's Avatar
My head gaskets are fine. It's my exhaust header gasket that goes. But I will keep those mls head gaskets in mind thanks.
---------- Post added at 07:21 AM ---------- Previous post was at 07:18 AM ----------
The gaskets came with lock washers I guess I'll use them with my header bolts see how that works out. I should get started later in today. Thank you for the compliment.
Old 02-27-2012, 05:45 AM   #7
Hahaha! Sorry, that happens sometimes when I'm groggy and not paying close attention to what I am reading. I completely missed the "er" on header.
As long as both surfaces are good and flat you shouldn't need any type of sealer.
If you ever need to reuse them they can be annealed by heating them cherry red with a torch and quenching them in water.
Old 02-27-2012, 07:23 AM   #8
I use Mr. gaskets ultra seals never have a prob
Old 02-27-2012, 07:27 AM   #9
Meansaleen's Avatar
Yup those are the ones I got. Anyone use any special tools besides a box end or socket? Just trying to mentally prepare myself for when I get started later on.
Old 02-27-2012, 10:05 AM   #10
I found it easiest to use 1/4 drive tools with swivel
Old 02-27-2012, 06:41 PM   #11
When using a one piece header gasket, I usually cut the bottom out of the two end holes.
That lets me attach the header with those two bolts and then drop the gasket into place on them instead of fighting the header and gasket trying to get a bolt started.
I prefer the small headed 12-point header bolts. They are much easier to get a 12-point wrench or socket on than the 6-point bolts.
header question. robert3188 1979-1995 Mustang GT 5 02-08-2012 10:06 AM
Another header question. AgentOrange 1996-2004 Mustang GT 17 02-07-2012 05:44 PM
2011+ header install. Reinkey 2011-2014 Mustang GT 16 02-01-2012 05:41 PM
Header experience Gibby 2011-2014 Mustang GT 11 01-26-2012 08:10 AM
header leak vigilnash_89lx 1979-1995 Mustang GT 10 01-22-2012 06:07 PM
09:12 AM
