What cam ?? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 02-26-2012, 04:30 PM   #1
Neverenough's Avatar
Neverenough is unknown around these parts
What cam ??
Im new to the forum and looking for some info on a new project I have . I'm not new to mustangs just been out of the game for a while . I picked up an 87 notch in pieces ! Super clean never seen winter and it came with a bunch of goodies , edelbrock upper and lower ported (engine is stripped these are all parts ) mass air converted built t5 Mac long tubes 65 mm tb 24 lb injectors . Heads are missing and so is cam . I also have an explorer engine with gt40p heads . So I want to build one engine out of the 2 . My question is what cam would work best with this set up ? Some porting to the heads and will I need to flycut pistons if I use the explorer short block ? Car has 4:30 gears too any help would be greatly appreciated ! Thanks !
Neverenough is offline
Old 02-26-2012, 05:38 PM   #2
WhiteCobra94's Avatar
WhiteCobra94 is unknown around these parts
Trick Flow stage 1 can with 1.6 or 1.7 rocker arms
WhiteCobra94 is offline
Old 02-26-2012, 05:52 PM   #3
Senior Member
dreamstang is unknown around these parts
is hard to say if youll need to knotch pistons or not.but try this www.camquest.com
dreamstang is offline
Old 02-26-2012, 05:53 PM   #4
Filibuster
XXSTEVEO66 is unknown around these parts
Never a bad idea to call the cam company you have in mind..you can tell them your exact setup so they can give you the best possible cam you're looking for!!..
Btw that sounds like a fun project you got there!..
XXSTEVEO66 is offline
Old 02-26-2012, 05:56 PM   #5
Senior Member
good advice.also a custom ground cam may net the best gains but will cost a little more.
Old 02-26-2012, 05:59 PM   #6
Thanks for the info I'll check into a few of them to see what they recommend .
Old 03-03-2012, 05:44 PM   #7
Ok so I picked up an x cam . I know there are plenty of other cams that will work better with my set up but it was free !! So next question is with my p heads (which I will upgrade for some edelbrock's as I replenish the budget ) is there a spring kit with adequate seat pressure for this cam without machining the heads ?
Old 03-03-2012, 06:49 PM   #8
You may have to degree the cam and definitely check piston to valve clearance , also you'll need a tune with that cam!
Old 03-03-2012, 06:55 PM   #9
Car originally had an x cam it's already been tuned and I have fly cut pistons
Old 03-03-2012, 07:03 PM   #10
O ok good!!
Old 03-03-2012, 07:18 PM   #11
Ya long story short I picked up a car that was part of a divorce so I got an amazing deal but he started to part it out and the cam and heads , a few other things are missing so I'm just piecing it together to have some fun with this year while I build a killer stroker for it .
---------- Post added at 09:18 PM ---------- Previous post was at 09:13 PM ----------
So I have everything the same as the p.o except he had performer rpm's with work done and I have a set of gt40p's for now
Closed Thread
What are you currently listening to? Brent The Bar 9838 Yesterday 11:29 PM
What did you do today? Qwik Four Six The Bar 17010 Yesterday 10:43 PM
98 3.8 in need of power.. cam? trixinahat Pre-2005 V6 Mustang 33 02-26-2012 08:40 PM
stock cam? 5.slow 1979-1995 Mustang GT 37 02-25-2012 09:09 PM
What to do first? Blackedout03 Pre-2005 V6 Mustang 2 02-25-2012 07:20 PM
02:24 PM
