torque box question - Mustang Evolution
Old 02-27-2012, 01:26 PM   #1
93_347foxbody's Avatar
torque box question
How complicated is it to reinforce the upper andlower torque box on a 93 lx? And if my current torque box isn't in that great of shape should I replace it or will the reinforcment kit get the job done?
93_347foxbody is offline   Reply With Quote
Old 02-27-2012, 07:55 PM   #2
Re: torque box question
The reinforcement kit will get the job done.
It should be welded in and depending on the damage you have, more welding may be required.
Old 02-27-2012, 07:59 PM   #3
im not quit sure of the damage but both of my rear shocks were dented, one busted, and the other snaped in half, i already replaced em but would that be cause of the torque box shifting or moving?
Old 02-27-2012, 08:20 PM   #4
Not unless it ripped the LCA's completely loose, but if that happened the car would be undrivable.
Old 02-27-2012, 10:20 PM   #5
etc1006's Avatar
If you have aftermarket LCA's they may be tearing the mounts. I have parted out cars in the past that had megabite arms on them and they were notorious for ripping the boxes. Get under there and clean it up real good and check. I do believe there are kits to beef them up.
etc1006 is offline   Reply With Quote
Old 02-28-2012, 07:37 AM   #6
The previous owner never reinforced the torque box when he swapped out the 4 cylinder
Old 02-28-2012, 11:04 AM   #7
I don't believe there is any difference in the torque boxes between the models.They are all relatively weak and tend to fail when you go drag racing and start launching hard with sticky tires.
Old 02-28-2012, 02:26 PM   #8
Alright I didn't know that I thought the 5.0 might have a stronger one or something
Old 02-29-2012, 03:32 AM   #9
Region: Alaska
I would look at a kit from wild rides. I just put on an upper kit from UMI and cannot recommend there upper kit to anyone. The were possibly the most ill-fitting product I have ever used. You may be able to just weld the torque box up without the reinforcement plates. I have read the as long as your making under 500hp you can just weld them and be fine.
91redfox is offline   Reply With Quote
Old 02-29-2012, 05:42 AM   #10
i already purchased a reinforcement kit, it wasn't from wild rides but hopefully it fits good im just gonna end up welding the torque box and put the reinforcement kit on
Old 02-29-2012, 07:21 AM   #11
captain78's Avatar
I think I got the torque box from umi from summit. Have put them in yet. But that should be this week. The plan is to weld up the boxes plus the reinforcement kits. My boxed where a Lil messed up but looks like it's from somebody using them to lift the car with a jack there. So not to bad just a Lil dented. Hoping to be fine
captain78 is offline   Reply With Quote
Old 02-29-2012, 07:58 AM   #12
Someone used the right side of mine to jack the vat up and the left side is rusted a bit just the lower torque box I think the uppers fine hopefully I gotta check when the weathers better I'm still gonna reinforce it too
Old 02-29-2012, 08:11 AM   #13
captain78's Avatar
Good cause it's better safe than sorry. IMO cause there's no telling how much horsepower I'm gonna put in my car over the next 20 yes or so lol
Tuner question StackeStang 1996-2004 Mustang GT 5 02-26-2012 08:14 AM
question about flowmasters 93_347foxbody 1979-1995 Mustang GT 12 02-24-2012 09:20 PM
Quick question about RPM's Mustang_Madness 1996-2004 Mustang GT 29 02-23-2012 06:55 PM
Heads Question 96gt014.6 1996-2004 Mustang GT 9 02-23-2012 06:48 PM
Question about cams 93_347foxbody 1979-1995 Mustang GT 8 02-23-2012 03:21 AM
11:33 PM
