South jersey - Mustang Evolution
Old 02-27-2012, 04:34 PM   #1
Matt5.0's Avatar
South jersey
Does anyone on here live in south jersey around vineland area. Looking for someone with good skills to help me replace a distributor, i will help and will pay a little.
Matt5.0 is offline   Reply With Quote
Old 02-27-2012, 07:03 PM   #2
Re: South jersey
Sorry, I'm not even close, but if you buy yourself a Chilton's or Haynes manual for your car, you should be able to follow the instructions on how to replace the distributor.
It is not all that difficult, it just requires attention to details.
Old 02-27-2012, 07:05 PM   #3
Matt5.0's Avatar
Yeah have one, and have self tought myself so far on everything i done so far but worried about f**king something up
Old 02-27-2012, 07:55 PM   #4
Re: South jersey
I wish I were close enough to help you, but that's not the case.
Just follow the instructions closely and if you have other concerns or questions post them up here and we'll do our best to help you.
One of the most important things to do is to bring the engine up to TDC on #1 cylinder, making sure you are on the compression stroke. You can check that by ensuring that both valves are completely closed. The rotor in the distributor should be pointed at the #1 spark plug wire connection if it is properly timed. Then, when reinstalling just make sure that the new distributor is installed in the same position. This is sometimes difficult to achieve and may take several tries to accomplish.
Also make sure when you pull the distributor that the oil pump driveshaft stays in place. If it comes up and drops into the pan, you will need to fish it out and put it back into the pump before reinstalling the distributor and starting the engine. It is actually best to replace the driveshaft with an aftermarket HD one while you have it apart if you can afford to do so.
SOUTH CAROLINA Doe_Rae_mi Regional Mustang Discussion 12 02-12-2017 11:04 PM
North Jersey/ NYC area gtstyles2 Regional Mustang Discussion 27 02-27-2012 06:38 AM
Hello From South Carolina Solomo2 New Member Introductions & Greetings 4 01-29-2012 08:54 PM
New from South Korea RumbleBee New Member Introductions & Greetings 20 01-20-2012 05:39 AM
South mississippi 96gt014.6 Regional Mustang Discussion 6 01-06-2012 08:23 PM
10:41 AM
