I need MAF conversion for dummies - Page 3 - Mustang Evolution
Old 04-04-2012, 08:27 AM   #71
87blackonblack's Avatar
sweet thanks man!
87blackonblack is offline   Reply With Quote
Old 04-07-2012, 01:54 PM   #72
when i install my gt 40 upper and lower and my maf conversion is there any thing i should do away with i believe this has the egr delete? is there a play by play i can follow?
Old 04-07-2012, 03:14 PM   #73
Re: I need MAF conversion for dummies
Check the Useful Info thread for a detailed article.
Old 04-12-2012, 10:50 AM   #74
starting my maf conversion this weekend finally have all the parts i need. after the install will i need a tune for my car to run right if so what are some suggestions please?
Old 04-12-2012, 11:05 AM   #75
Titus Wadicus
svtlx's Avatar
whhhhy would you need a tune? am i missing something?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-12-2012, 11:12 AM   #76
Svtlx is right.unless you are fully built the computer and sensors should be able to handle your needs.
Old 04-12-2012, 01:23 PM   #77
The only tune you will need is to make sure:
your spark plugs are good and gapped correctly,
wires are in good shape,
rotor and distributor cap are in good shape,
timing is set correctly,
and your fuel pressure is correct.
If all those things are in good order, the ECU will take care of the rest.
Old 04-12-2012, 02:24 PM   #78
i have brand new msd cap and rotor plus ford racing wires and new plugs. fuel pump i'm not sure how old it is but i have good pressure. i'm excited to start this just nervous ilL mess it up.
---------- Post added at 03:24 PM ---------- Previous post was at 03:24 PM ----------
as far as timing what should out be set at
Old 04-12-2012, 02:42 PM   #79
Being nervous is understandable when tackling a project you know little about, but that's how you learn. Just jump in with both feet and be prepared to do whatever it takes to see it to its conclusion.
I would set the timing at the factory 10 degrees BTDC to start out with, then advance it later when everything is working well.
Old 04-16-2012, 08:39 PM   #80
http://orlando.craigslist.org/pts/2952916755.html
what is this.what does it do and is it worth looking into?
Old 04-16-2012, 08:50 PM   #81
87-93 Mustang ADS performance module
Never heard of an ADS Superchip.
I'd leave it where it is.
Old 04-16-2012, 09:07 PM   #82
351mustanggt's Avatar
+1 it supposibly adds lots of hp and mpg lol. stay far away from that!!! major rip off
351mustanggt is offline   Reply With Quote
Old 04-16-2012, 09:40 PM   #83
me either i didnt no if it was something worth buyin and re selling or not. thanks for the info.
Vote for your favorite T-shirt 99ford The Bar 96 03-26-2012 09:13 PM
Putting in wiring for amp 2003SonicBlue Mustang Audio & Video 5 03-02-2012 09:30 PM
Autometer Lunar Series Gauges for 99-04 V6 runvsofthisbull Mustang Parts for Sale and Wanted 3 02-29-2012 07:28 AM
Hello, need a little help. 89 coupe 1979-1995 Mustang GT 4 02-27-2012 08:37 PM
Looking at a used T45 need help!!! 1995boss 1979-1995 Mustang GT 2 02-26-2012 11:15 PM
12:22 PM
