Problematic 94 gt 5 speed no mods(yet) - Mustang Evolution
Old 02-28-2012, 07:42 AM   #1
Cstyle1's Avatar
This is my first post to this forum but I read everyday and get great information from you guys. So... If I dont let my car warm up long enuf wen I give it gas its like the car almost wants to die and I can hear some kind of back fire. After the car is warmed up I dont have this problem. I do know I have an exhaust leak where the muffler and pipe are welded. Is there a quick fix for this? Jb weld? Or something of the sort? And lastly.... My car accelerates like its a 4 cyl mazda or something. Check engine light comes on very rarely, maybe once every 2 or 3 months. Car has a strong fuel smell when its first started. I appreciate any help and guidance. I am gonna use my code scanner today and see what I get.
Thanks
Cstyle1 is offline   Reply With Quote
Old 02-28-2012, 08:20 AM   #2
I would start with the basics.plugs, wires, cap and rotor,fuel filter etc.then check your Iac ,maf, tps.and wouldn't hurt to see what your fuel pressure is.
Cleaning the parts I mentioned and making sure they are set properly.
Old 02-28-2012, 08:21 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Problematic 94 gt 5 speed no mods(yet)
YOU NEED A FULL TUNE-UP. the plugs are toast, they are break'n up when its cold. do plugs, wires, dizzy cap and button. and hopefully your cats arent effed up from letn the plugs get so bad if the fuel smell is as bad as u say. tune it up and go from there.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-28-2012, 10:55 AM   #4
I agree with both posts above and add, buy a manual for your car to help you with the procedures mentioned. Along with damaging the catalytic converters, your O2 sensors may need replacing too.
JB weld or any other epoxy is not going to hold up on the exhaust for very long.
You will need to weld or replace the pipes.
Old 02-28-2012, 11:50 AM   #5
Cstyle1's Avatar
I had it tuned up last May but the car sat for 4 months. So thats really only 6 mos on the plugs and wires etc. I just really want to get my car feeling like a 5.0 should. And not feeling like a 5. slow. Thanks for the advice . Im going to try everything
Old 02-28-2012, 11:56 AM   #6
Titus Wadicus
svtlx's Avatar
maybe the guy used cheap plugs... ive ran into the same problem several times tryn to save money. idk... or u could have gotten sum bad wires, thats happened to me too
Old 02-28-2012, 12:07 PM   #7
This theory fan be checked by pulling each wire off individualy and checking them for spark.
Old 02-28-2012, 01:47 PM   #8
Cstyle1's Avatar
The thing is my car had decent acceleration for awhile after the tune up. And then one day it just started acting up and running real sluggish. It feels like im dragging a ton of bricks
Just suppose ... What are some mods / changes u would make Regancmmd 2005-2010 Mustang GT 5 03-10-2012 11:42 AM
which throttle to go with on 99 gt 1quick4.6 1996-2004 Mustang GT 15 03-04-2012 07:51 AM
GT Rear Badge Paint Attempt avengnd 2011-2014 Mustang GT 36 03-01-2012 08:58 AM
website> app Timm04 The Bar 6 02-28-2012 10:44 PM
2011 mustang gt turbo Trymygt 2011-2014 Mustang GT 4 02-28-2012 12:59 PM
12:25 PM
