Fuel leak - Mustang Evolution
Old 02-28-2012, 03:52 PM   #1
Quball19's Avatar
Fuel leak
Ok I know then bbk ssi intake has fuel leaks , how can you fix, or can you put different fuel rails on to solve it? Any help I would love
Thanks
Quball19 is offline   Reply With Quote
Old 02-28-2012, 04:00 PM   #2
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
You mean the crossover pipes on them? Could be as simple as using a different o-ring on them. If your talking about the rails themself, I've never seen that problem on then. I'm running the Bbk ssiR intake which uses the same rails and I haven't had a problem with them leaking.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-28-2012, 04:03 PM   #3
Quball19's Avatar
Yes cross over tube . So just replace o-ring? Can get at any auto parts store?
Old 02-28-2012, 04:07 PM   #4
Pete Jones
You might be able to but idk for certain, just make sure you get the right size o-ring meaning the same size that came out, maybe grab one size bigger and give that a shot. Just make sure you don't pinch the o-rings when putting it back together. Replace them them put it together, then prime the system and check for leaks, you shouldn't have to put the upper on to check for leaks.
90 LX hatchback
89 LX Notchback
Old 02-28-2012, 04:10 PM   #5
Quball19's Avatar
Cool thanks ill try that
Old 02-28-2012, 04:12 PM   #6
Pete Jones
By bigger size I mean thicker not a larger size
90 LX hatchback
89 LX Notchback
Old 02-28-2012, 04:13 PM   #7
Quball19's Avatar
Got it thanks
Old 02-28-2012, 04:41 PM   #8
Cobrarunnin9s's Avatar
Re: Fuel leak
Also use white lithium grease on the o-ring before you put the rail on.
Cobrarunnin9s is offline   Reply With Quote
Old 03-01-2012, 06:18 PM   #9
Quball19's Avatar
Ok tried o-ring didn't seem to work, heres what I have to ask ..can you weld the cross over tube holes, an run a fuel line around back of rails where the holes are plugged... Now I have a bbk ssi intake ..ready to bite a nail into ...or (lol) just get new rails but I have to use bbk rails don't know if improved or not ...PLEASE HELP!!!
Old 03-01-2012, 07:08 PM   #10
Pete Jones
Is it leaking around the o rings? You did bolt the rails back down after putting the new rings on so they are seated right?
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 03:07 AM   #11
Quball19's Avatar
Yes I did
Old 03-02-2012, 03:42 AM   #12
Re: Fuel leak
Can you get some pictures of the problem areas?
Old 03-02-2012, 03:52 AM   #13
Quball19's Avatar
I will,it will be later in day
Old 03-02-2012, 04:43 PM   #14
Quball19's Avatar
This is where it leaks
Old 03-02-2012, 04:55 PM   #15
Pete Jones
It doesn't look like the o ring is in all the way
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 04:57 PM   #16
Quball19's Avatar
Thats add far as it will go in , once tighten down rails it wants to pull apart
Old 03-02-2012, 05:03 PM   #17
Pete Jones
Hmmm, so it basically pulls the rail away from the lower when you tighten it down.... Try using 2 o rings on each side then tighten it down and see if that helps
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 05:06 PM   #18
Quball19's Avatar
I will try, This might be dumb quetion but hey ....can the cross tube be welded on to rails?
Old 03-02-2012, 05:08 PM   #19
Pete Jones
Honestly I don't know, you MIGHT be able to tap the holes and put a screw in plug in them then use a flex type gas line that screws into each side on the back of each rail but sounds like more headache than anything
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 05:11 PM   #20
Quball19's Avatar
Thanks for your help, not really sure what going to do .. Really pissing me off but determined to get this ssi intake an rails to work
Old 03-02-2012, 05:13 PM   #21
Pete Jones
Yeah I can understand your frustration, give the 2 o rings on each side of the tube a shot, I'm almost certain that should help
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 05:15 PM   #22
Quball19's Avatar
I will had to walk away from it for awhile lol .... Thanks alot ill let you know how it comes out
Thanks again
Old 03-02-2012, 05:20 PM   #23
Pete Jones
Not a problem, that's what we are here for heh, good luck!
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 05:48 PM   #24
Re: Fuel leak
Attachment 42285
OK, after quite a bit of research into this and not really finding a good fix, I have sent an email to BBK requesting information on how this issue can be resolved.
In the mean time I have a couple of ideas if you want to try them.
1. Try installing the tube with 2 or more o-rings (not sure how many will actually fit) pressed onto each end of the tube. Lubricate them and be careful installing to ensure the o-rings do not get cut or slip over the end of the tube.
2. This mod idea may destroy the crossover tube so use it at your own discretion.
First, try to stack at least 2 o-rings onto each end of the tube, then "very carefully" flare the end of the tube out to where it will just fit into the rails. If you go a bit to big you can file down the circumference with a metal file. Be sure to blow away any metal filings. You should be able to attach a flaring tool right behind the bulge in the tube on each end and flare out the end. As an alternative if you do not have access to a flaring tool, the tube can also be flared on the ends with a small ball peen hammer, taking care to not get off centered or strike too hard and damage the tube. A second hammer and friend to help hold the tube or strike the ball peen would be a big help. Set the rounded end of the ball peen into the end of the tube and tap the face of it with another hammer to flare the tubing end.
My theory for the second idea is that with the tube end flared out it will restrict the movement of the crossover tube and the flared end will help direct the pressure through the tube better, leaving less of it to try and push past the o-rings.
Old 03-02-2012, 05:54 PM   #25
Pete Jones
+111111 I was going to suggest emailing Bbk but I've read on another mustang forum that they havent been getting any help with the issue from them, basically saying they have never heard of that issue but ya never know
90 LX hatchback
89 LX Notchback
Old 03-02-2012, 05:54 PM   #26
deadsp0t's Avatar
Are the rails used? Is there any chance the tube or rails could have been damaged?
That's unimpressive
Old 03-02-2012, 05:58 PM   #27
Quball19's Avatar
Kinda what I was thinking , yes came with car, thought about buying new ones and go from there, its ti bad can't use different ones
Old 03-02-2012, 08:09 PM   #28
Re: Fuel leak
Well they can't claim that with my email.
I told them I did some searching and turned up dozens of issues with it, so anyone with half a brain would know to do the same type of search and see what turns up.
I also told them I was interested in buying, so that might get them moving, who knows/
Old 03-02-2012, 08:13 PM   #29
Re: Fuel leak
You can do several different things.
1. Try the fixes I suggested.
2. See about getting a welding shop to TIG the holes shut and reroute a line around the back.
3. See if a machine shop can thread the holes and use some adapters and hard line to replace the crossover.
4. See if a welding shop can weld some fittings in there to do the same as #3 with hard line.
5. Take it off, go to BBK's business place and toss it through their front window.
Old 03-02-2012, 09:12 PM   #30
deadsp0t's Avatar
5. Take it off, got to BBK's business place and toss it through their front window.
I'd do #5... Except I'd add the intake too!
That's unimpressive
Old 03-03-2012, 05:19 AM   #31
Quball19's Avatar
I like number 5 that sounds tge best lmao
Old 03-03-2012, 04:36 PM   #32
Quball19's Avatar
Ok found good tig welder, will let you know out come next week .....
Thanks guys.. crossing fingers hope this works it should
Old 03-05-2012, 10:35 PM   #33
Re: Fuel leak
Reply from BBK about fuel crossover leak issues.
Originally Posted by Dave from BBK
The only major issue I'm aware of that we had in the past was the cross-over leaking. This was because of the o-rings not holding up properly. For customers with that setup, we sent out multiple o-rings that can be doubled up to provide a better seal. This was a while ago and since then we have upgraded the kit with new rails and a cross over that uses two aircraft grade aluminum 90 degree fittings and a piece of locking fuel line.
- Dave
Old 03-06-2012, 04:10 AM   #34
Quball19's Avatar
So, basically I am turning my old ones to new ones. Mine are welded up getting ready to repaint them and hook back up with my 90 degree lines. Thank you
Old 03-06-2012, 06:11 AM   #35
Re: Fuel leak
That's what it sounds like.
They should have replaced yours with a new set though, if they admitted there was a problem with them.
You're welcome and good luck.
05 Mustang fuel gauge jeepstang 2005-2010 V6 Mustang 8 03-04-2012 08:53 PM
Fuel issue? Chefnick 1979-1995 Mustang GT 1 02-27-2012 06:58 PM
Fuel injectors Swangin_Stangs 1979-1995 Mustang GT 3 02-24-2012 09:02 PM
Fuel pump captain78 Mustang Parts for Sale and Wanted 1 02-24-2012 07:20 PM
351w in an 85 mustang with a carb and fuel regulator five_0_85stang 1979-1995 Mustang GT 7 02-24-2012 08:32 AM
05:16 PM
