1989 gt - Mustang Evolution
Old 02-29-2012, 12:20 PM   #1
Jbeas50's Avatar
1989 gt
How can I make my stock 1989 5.0 gt faster at a cheap price
Jbeas50 is offline   Reply With Quote
Old 02-29-2012, 12:38 PM   #2
See the sticky thread "in the beginning".it will list a good order of stuff to do to your stang.
A free mod u could do is advance your timing.if you don't know the process you can find other threads or let us know and we'll give you the run through.
Old 02-29-2012, 12:39 PM   #3
deadsp0t's Avatar
This•^•^•
That's unimpressive
Old 02-29-2012, 12:46 PM   #4
Jbeas50's Avatar
Ok thanks what type of part should I start with I have about 1500 right now to put in it
---------- Post added at 01:46 PM ---------- Previous post was at 01:42 PM ----------
Also how do I do what you just told me
Old 02-29-2012, 12:52 PM   #5
stampde's Avatar
Re: 1989 gt
damn a STOCK , Unmolested 5.0 ? don't see them to often ...
advance the timing to "14
remove the airbox muffler , its in the fender well connected to your air box
and get a K&N replacement filter , or just trash the whole airbox and put a CAI in
exhaust , and gears and if you have the $$ and intake manifold does wonders too , along with a set of 1.7 Cobra roller rockers ...
those are the first and cheapest things you can do
2011 GT Auto
Old 02-29-2012, 02:16 PM   #6
Mustang Modifications - In the Beginning...
Old 02-29-2012, 05:15 PM   #7
Jbeas50's Avatar
Around how much does this whole set up cost
Old 02-29-2012, 05:19 PM   #8
advance timing - free
gears. - 260 if you install
intake new -250-500. used. 50-200
k n filter -50
1.7 rr - 150-250
---------- Post added at 06:19 PM ---------- Previous post was at 06:18 PM ----------
mufflers 1-200
h or x pipe 150-250
header 100-250
cai. 100-200
Old 02-29-2012, 08:10 PM   #9
87blackonblack's Avatar
Now with all of these mods should he have to get the car tuned or would it be ok with the stock tune?
87blackonblack is offline   Reply With Quote
Old 02-29-2012, 09:27 PM   #10
Imo you would be ok getting a chip from AM.when u get a little bit more into it a tune may be required.
Old 02-29-2012, 10:04 PM   #11
Re: 1989 gt
It will be fine with the stock ECU.
I have a boatload more mods than that and I'm still running the stock ECU with no tune or chip.
Like dreamstang said when you get farther into it, a chip or tune could help you pick up some additional horsepower, but for now you will be ok.
Old 03-12-2012, 09:52 AM   #12
Will these mods still be okay with a stock speed density cpu
Old 03-12-2012, 10:03 AM   #13
Re: 1989 gt
Any mods that increase the air flow much on a speed density car will cause problems.
Your first mod should be to convert it to MAF.
Old 03-12-2012, 10:07 AM   #14
Dkerk8's Avatar
Underdrive pulleys also help alot.. I have them on mine and its a noticeable difference
Dkerk8 is offline   Reply With Quote
Old 03-12-2012, 10:11 AM   #15
Re: 1989 gt
Not really a fan of those.
Usually they cause charging problems and require the installation of a larger alternator on the 79-93 models.
Old 03-12-2012, 10:15 AM   #16
Dkerk8's Avatar
I have n 89' and havent had any issues at all n ive been running them for 2 yrs n have never had a dead battery or anything
Old 03-12-2012, 10:23 AM   #17
Re: 1989 gt
You're an exception or maybe someone previously changed out the alternator for a larger one?
They usually cause problems with discharging when the engine is idling.
Old 03-12-2012, 10:29 AM   #18
Dkerk8's Avatar
My car was completely stock when i bought it.. All original everything.. But ya idk i love having them
---------- Post added at 11:29 AM ---------- Previous post was at 11:28 AM ----------
I would also suggest headers.. They help alot cause engine can actually breathe
Old 03-12-2012, 11:10 AM   #19
351mustanggt's Avatar
i thought an 89 had mass air?
351mustanggt is offline   Reply With Quote
Old 03-12-2012, 11:13 AM   #20
Dkerk8's Avatar
Mine does..i didnt think they were carburated anymore after like 87 or 88?
Old 03-12-2012, 11:19 AM   #21
88 was the last year of speed density i thought
Old 03-12-2012, 11:25 AM   #22
Dkerk8's Avatar
Ya me too cause all the 89's ive seen are maf
Old 03-12-2012, 11:51 AM   #23
Re: 1989 gt
It does.
The person I responded to has an 87.
Old 03-12-2012, 12:19 PM   #24
Meansaleen's Avatar
88 was the last year for speed density. 88 California Stangs had a maf
Meansaleen is offline   Reply With Quote
Old 03-12-2012, 12:28 PM   #25
Re: 1989 gt
STOP!
There was a misunderstanding about one of my responses that started this whole discussion on what year Mustangs had MAF.
The person I responded to has a 1987 which is speed density.
Refer back to where the MAF discussion started to see the response.
Meansaleen is correct with his answer.
Old 03-12-2012, 12:38 PM   #26
woops my bad
Old 03-12-2012, 12:39 PM   #27
Re: 1989 gt
woops my bad
No biggie, it was just starting to snowball though.
Old 03-12-2012, 04:36 PM   #28
Haha my fault guys I started this lol. Yes my car its an 87 with speed density and I have headers x pipe flowmaster 10 and a gt40 upper and lower intake. I have not switched to maf yet because my funds ran out for the time being. So my question originally was if the guy who was doing similar mods as mine if it would all work on the original CPU which his would because be has maf but my question is which of these mods of mine would be ok to use with speed density until I could convert to maf?
I was not a member of this forum when I bought my car or maf would have been the first mod.
Also what's a good spark plug to use?
---------- Post added at 05:36 PM ---------- Previous post was at 05:35 PM ----------
O none of these have been installed yet only the cai has
Old 03-12-2012, 05:25 PM   #29
Re: 1989 gt
I wouldn't install to much until you have been able to convert it to MAF.
That way if you have any issues they might be easier to diagnose and repair.
You could low buck the MAF conversion by maybe finding a wrecked car or one that someone is changing to carb.
I believe the Autolite 25 plug will work for your car.
You can mod them a bit if you wish, but it will reduce the life of the plugs.
Take a look in the Useful Mustang Info thread for plug mods.
Old 03-12-2012, 05:53 PM   #30
Thanks Trojan your like Yoda of mustangs haha. I will have to look at some odd the junk yards to see what they have maybe I'll get lucky
Old 03-12-2012, 06:06 PM   #31
sometimes i personally have problems finding mustangs at the boneyard.they are like gold.but if you cant find anything try contacting emmetheadperformanc.the are a site sponsor and have a huge mustang boneyard.tell them ou are from the forums and they might take care of you.
Old 03-12-2012, 06:11 PM   #32
Re: 1989 gt
Welcome you are.
dreamstang has a good idea.
Might also try stangparts online, but they'll be higher I bet.
Old 03-12-2012, 08:50 PM   #33
Awesome love this forum
Old 03-19-2012, 04:18 PM   #34
Ok long tube header question again? Does my motor have to come out to install these or just take the starter of and do some dominatrix with them lol
Old 03-19-2012, 05:05 PM   #35
I haven't installed long tubes yet.but you definitely don't have to pull motor.and never heard of anyone pulling the starter either.but the dominatrix is more accurate.
I would suggest buying header bolts though.they have a smaller head than normal , so it helps getting a wrench or socket on them.because you will have less room by the bolts since the new headers have larger than stock pipes.
which intake plenum to go with on 99 gt? 1quick4.6 1996-2004 Mustang GT 11 03-07-2012 09:54 PM
GT Rear Badge Paint Attempt avengnd 2011-2014 Mustang GT 36 03-01-2012 08:58 AM
Selling my '05 GT Wheels with new Zeon RS3's on eBay righter86 Mustang Wheels & Tires 0 02-29-2012 06:55 AM
website> app Timm04 The Bar 6 02-28-2012 10:44 PM
04 GT automatic TXstang125 1996-2004 Mustang GT 2 02-28-2012 09:28 PM
01:22 PM
