clutch problem - Mustang Evolution
Old 03-03-2012, 08:49 PM   #1
clutch problem
I Gao an 84 gt it has a new clutch and cable and now when the cat gets warm I won't shift into any gear it works when its cold or I'm sitting still any thoughts on what it could be I'm lost thanks
pandm0811 is offline   Reply With Quote
Old 03-03-2012, 09:44 PM   #2
Re: clutch problem
How does the pedal feel?
Have you tried lifting the pedal with your toes to see if the clutch cable will self adjust.
Was the quadrant replaced along with the cable?
The factory plastic quadrants are known to fail.
Also possible is that the front bearing cover and TOB tube are aluminum which get worn and stick.
Old 03-04-2012, 08:40 PM   #3
The pedal feels ok and I got the cable adjusted all the way
Old 03-04-2012, 09:03 PM   #4
Re: clutch problem
Get some help.Lift and support the car properly.
Remove the inspection cover on the bell housing.
Have someone operate the clutch so you can verify it is working and the throw out bearing is not sticking on the guide tube. If you can tell that the guide tube is aluminum, it needs to be replaced with a steel or cast iron version.
A good portion of the aftermarket clutch cables are not very well made and it may be stretching.
Maximum Motorsports sells one of the best cables you can get.
It is made exactly like the factory cables and it holds up better than anything else you can buy.
It may be that your transmission synchronizers are just worn out or that your shifting forks in the transmission are bent. Verifying or correcting would require transmission removal and tear down, so I would make sure everything else is up to snuff before going this route.
Old 03-04-2012, 09:19 PM   #5
Ok thanks for help man I appreciate it
Old 03-04-2012, 09:29 PM   #6
Re: clutch problem
No problem, let us know what you find.
Smoking problem with the 5.0 1995boss 1979-1995 Mustang GT 20 03-07-2012 10:13 AM
Clutch Goes Chirp! jjsg09 1996-2004 Mustang GT 10 03-07-2012 07:26 AM
New clutch Califas gt 1996-2004 Mustang GT 19 03-07-2012 03:17 AM
Oil Pressure Guage Problem FORDGT14 1996-2004 Mustang GT 6 03-03-2012 06:54 PM
guage problem fastback67 Classic Mustangs 7 03-02-2012 08:33 PM
04:08 PM
