pulley configuration - Mustang Evolution
Old 03-04-2012, 08:54 AM   #1
bcosta56's Avatar
So I'm planning on doing a smog and a/c delete and I've seen certain things like reverse flow water pumps and underdrive pulleys etc kind of threw me off a bit.. I just need to know what exactly I have to do to make it just run PS,waterpump,alternator,crank. Other than the obvious shorter belt, do I need new brackets, pulleys, or anything I need to modify or be of careful when purchasing as far as making sure it will work for this application?
bcosta56 is offline   Reply With Quote
Old 03-04-2012, 09:09 AM   #2
WhiteCobra94's Avatar
You can buy delete brackets or a shorter belt and bypass the smog/AC
Old 03-04-2012, 09:43 AM   #3
88gtCc's Avatar
Should just need the delete "kits" and a shorter belt. I have included a pic that has a few different configs (belt size included)
88gtCc is offline   Reply With Quote
Old 03-11-2012, 05:31 PM   #4
shawnpbigelow's Avatar
Just did the smog pump delete. The chart helped a bunch thanks.
shawnpbigelow is offline   Reply With Quote
Old 03-11-2012, 07:54 PM   #5
Taxman's Avatar
Did you use the ac an smog delete brackets?
Taxman is offline   Reply With Quote
Old 03-11-2012, 07:58 PM   #6
No. I pulled the smog pump out and got an 84.5 " belt and it worked.
3.4" pulley! syrupsaleen Saleen & SMS Mustang 155 03-30-2012 09:25 PM
96 5 speed. underdrive pulley ?s clifford Pre-2005 V6 Mustang 0 02-23-2012 07:52 PM
S/c pulley and fmu f/s Meansaleen Mustang Parts for Sale and Wanted 1 02-06-2012 06:32 AM
94gt ud pulley prob Sky94GT 1979-1995 Mustang GT 3 02-03-2012 06:46 AM
Crank pulley Sonicblue05 2005-2010 Mustang GT 2 12-29-2011 06:29 AM
12:16 AM
