Aode to a c-4 - Mustang Evolution
Old 03-04-2012, 07:53 PM   #1
FordRacer_51's Avatar
Aode to a c-4
Does anyone know what it would take to go from an aode trans to a C-4 in my 94 gt??
FordRacer_51 is offline   Reply With Quote
Old 03-04-2012, 09:19 PM   #2
Re: Aode to a c-4
Why would you want to?
The AOD and AODE are basically the C-4 with overdrive added.
I'd just build the AODE and keep the overdrive or your gas mileage will suffer significantly.
You can get the Baumannator control to electronically alter your shift points and firmness without tearing into the transmission, but a performance rebuild should be done first.
Old 03-04-2012, 09:27 PM   #3
I have the aode out and ready to send it to get rebuilt and also have a b&m shift improver kit to go in it but I ran on to a c-4 but he wants a Ton of money for it so I was just wondering?? And when I take that to get rebuilt is there a performance parts in it or should I take it to a race shop or what???
Old 03-04-2012, 09:33 PM   #4
Re: Aode to a c-4
If possible find someone knowledgeable about the AODE.
There are several areas that need to be improved for performance use.
Read through this site Ford - AODE to get an idea of what should be done.
The C-4 would be good for a drag race only car, but I wouldn't run one on the street anymore with gas prices being what they are.
Old 03-04-2012, 10:13 PM   #5
What are the chances I have a 4r70w??
Old 03-04-2012, 10:27 PM   #6
Re: Aode to a c-4
I don't know for sure.
Check the numbers on the tag.
You can Google search them to find out.
It would be good if you did have one.
They are supposed to be a bit stronger and better than the AODE.
Old 03-04-2012, 10:32 PM   #7
I see so just google the numbers on the side?? And I also googled the power pack on the web site too I found a bunch of good parts on there too!!
Old 03-04-2012, 10:42 PM   #8
Re: Aode to a c-4
I don't know if the numbers cast into the case will tell you, but the numbers stamped into the tag should.
Always nice to find out you have more than you thought you had.
What are you currently listening to? Brent The Bar 11215 09-07-2016 06:12 PM
Injustice to a Mustang GT. Mustang_Madness 1996-2004 Mustang GT 52 03-09-2012 07:29 AM
Your favorite place to drive in your city Davey4.0 2005-2010 V6 Mustang 8 03-04-2012 07:10 PM
Convert v6 to v8 Fastbullitt Pre-2005 V6 Mustang 7 03-04-2012 12:22 AM
Replace a Convertible to a hard top?, MustangGT94 1979-1995 Mustang GT 16 03-03-2012 06:53 PM
08:38 PM
