msd 6al - Mustang Evolution
Old 03-05-2012, 08:25 AM   #1
msd 6al
Hey guys I was wandering if there was a sticky or something showing how to install the msd box on a 94 gt. I know how to do most of it except mabye two wires
Robbie94gt is offline   Reply With Quote
Old 03-05-2012, 08:40 AM   #2
Titus Wadicus
svtlx's Avatar
Re: msd 6al
if you check msd's website, they have an adobe file with several installation instructions for different applications...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-05-2012, 08:41 AM   #3
Re: msd 6al
Go to the MSD website for wiring Instructions & Wiring DIagrams
They have wiring diagrams of almost every type of installation.
Don't guess or you may burn up the box.
Old 03-05-2012, 09:12 AM   #4
Gotcha ,I'll do that thanks. Yeah I wouldn't want to burn it up. And r those pretty reliable and last for a while with no problems out of it. What's your thoughts on the 6al box in general. Trogenhorse
Old 03-05-2012, 09:20 AM   #5
Re: msd 6al
I've used MSD ignition for the last 20 years or so with little to no problems and they work great. You will notice a smoother idle and increased engine response.
Just do NOT get zapped by a bad plug wire. It will make you hurt yourself getting away from it.
Old 03-05-2012, 09:44 AM   #6
Titus Wadicus
svtlx's Avatar
Re: msd 6al
+1^..... and make sure ignition is turned off lol. its pretty close to getting hit by a taser in my opinion.
i have a 6al thats a few years old on my stang. and a 6a that is on my caprice thats been in service for me since 95, and was in service on another race car (89 ranger wit 347 &fiberglass cab)waaay before i got it. so id say 15+ years makes it pretty reliable.
Old 03-05-2012, 10:00 AM   #7
stampde's Avatar
Re: msd 6al
don't mount it in the engine compartment , I've had issues with them getting hot before and shutting off ... but moved it to the cowl area where the wiper trans is and problems went away , so every time after that that's were I mounted them ...
2011 GT Auto
Old 03-05-2012, 10:57 AM   #8
Alright. Thanks guys that's what I wanted to hear. I looked on the website and got the instructions. Seems easy enough
Old 03-05-2012, 03:40 PM   #9
If your using iphone they also have an app with tech info m,install instructions etc
Old 03-05-2012, 06:35 PM   #10
Thansk u dreamstang I'll look into that.
MSD two-step 11stangGT 2011-2014 Mustang GT 9 01-26-2012 04:43 PM
msd install dreamstang 1979-1995 Mustang GT 2 12-04-2011 05:28 PM
MSD distributor DDubs 1979-1995 Mustang GT 8 11-16-2011 02:29 PM
MSD 2-Step Box 20115oh 2011-2014 Mustang GT 4 11-15-2011 02:48 PM
How to use MSD BTM Lapida 1979-1995 Mustang GT 16 11-07-2011 06:14 PM
04:27 AM
