Getting the car out of storage - Mustang Evolution
Old 03-06-2012, 09:10 AM   #1
89Saleen141's Avatar
I stored the car in a public storage facility over winter. I went to start it only once do to me juggling school and work. I went yesterday to try to start it and brought one of my friends just in case it needed to be jumped. It would not get enough juice from his battery to start, now i'm wondering how i can possibly get the car out of there. I really don't wanna buy a new battery. Oh yeah and I only have a week to get it out otherwise I will be charged for another month.
89Saleen141 is offline   Reply With Quote
Old 03-06-2012, 09:20 AM   #2
Re: Getting the car out of storage
If the battery went completely dead it may need to be slow charged with a charger.
It's also possible that it went bad and will not charge which would require a new battery.
Usually if they won't jump start the battery is either completely dead or the cables you are using are not conducting the power very well because the cables are bad or the car you are using isn't producing enough juice.
Old 03-06-2012, 09:24 AM   #3
Alrite, I'll look for someone with a portable battery charger or use a car with a newer battery to jump it again.
Old 03-06-2012, 09:30 AM   #4
If you try jumping it again, be patient and let the charging car run for 5-15 minutes before trying to start your car. If the battery is dead it will take some time to recharge and low voltage is hard on your electronics.
Old 03-06-2012, 10:35 AM   #5
Titus Wadicus
svtlx's Avatar
trojan horse is right... just take the battery out and take it to autozone or other parts retailer and let them trickle charge it. that way if its bad, ur not wasting ur time and friends gas at storage unit tryn to jump a car that wont start...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-06-2012, 10:46 AM   #6
TY for the support post.
Old 03-06-2012, 10:54 AM   #7
Titus Wadicus
svtlx's Avatar
dats wut frenemies are for....lmao
Old 03-06-2012, 11:06 AM   #8
Indeed!
Old 03-06-2012, 04:00 PM   #9
1995boss's Avatar
Trickle charge my friend. Bump Trojans thought.
1995boss is offline   Reply With Quote
Old 03-06-2012, 06:06 PM   #10
Yeah i got it out! Tried jumping it as you explained, nothing. Tried a jumper pack, nothing. Waited a bit and tried a fresh jumper pack and boom, she got running. Drove her for a good amount of time and let her idle for a bit. Started her again a few hours later and back up and running smoothly. Only downside is that all the power steering came out and i have pretty much lost power steering. Not that bad though, may just bypass it if possible.
Old 03-06-2012, 06:14 PM   #11
i wouldnt bypass it.it will be a pita to drive.explain more about the power steering.maybe we can help u fix it.
Old 03-06-2012, 06:25 PM   #12
1995boss's Avatar
You WANT power steering. Haha we really don't know how lucky we are to have that sometimes. It's almost a chore to drive with out it.
Old 03-06-2012, 06:27 PM   #13
if a car was designed without it and has a steering box its not as bad.but when u just take off a pump its pretty terrible.lol
Old 03-06-2012, 06:29 PM   #14
Yeah, that was just my excited, cheap side coming out. I could hear it whining when i'm in full lock and i saw the huge dried up puddle. It drips very very slowly, before I put it away it would be a few drops every night it seemed. So i guess the pump is dying out as well as leaking, cause i don't see it leaking from a hose.
Old 03-06-2012, 06:33 PM   #15
i would fill it up.and try to find a leak.if you dont have much money i have fixxed some leaks with epoxy putty and they held up just fine.if you run it to long with no fluid you may damage the pump.when u add fluid to it use some cleaner/degreaser and clean the pump up really good.it will help u pin point the leak.
Old 03-06-2012, 06:35 PM   #16
1995boss's Avatar
I had a BAD leak in my 93lx when I was in high school. It wasn't a very expensive fix.
Old 03-06-2012, 06:42 PM   #17
good point boss.now that you say that , i think i paid 50-60 dollars for a remanufactured pump from summit.
Old 03-06-2012, 06:45 PM   #18
Cool, I will try to pinpoint the leak myself and fix it with epoxy since I have some laying around. If it is dying out, what should I do?
Old 03-06-2012, 06:56 PM   #19
1995boss's Avatar
Well depends on the problem. If its a seal then it's still an easy fix.
Old 03-07-2012, 04:37 AM   #20
If the pump was dry and you ran the engine for more than a few seconds, then the pump is toast. Adding fluid or fixing a leak at this point won't do you any good. Most of them use some type of phenolic vanes to pump the fluid and friction from no fluid burns them up very quickly.
Old 03-07-2012, 08:43 AM   #21
Titus Wadicus
svtlx's Avatar
sooo true... i messed one up before firing up a fresh motor and forgot to put fluid in it
Old 03-07-2012, 08:29 PM   #22
It wasn't bone dry yet, I filled it up with some more fluids for now.
Old 03-07-2012, 08:30 PM   #23
when u filled it did the whine go away?if so you may be ok.
Old 03-07-2012, 08:46 PM   #24
Nope, driving it today I could still hear the pump whining. Sadly.
Old 03-07-2012, 08:50 PM   #25
the damage has probably already been done then.
like i said earlier you can get a remanufactured pump pretty cheap from summit.just keep fluid in yours till you can get it,to get you by.
be sure to use the proper puller to take the pulley off.i have damaged one not doing it correctly.
good luck
Old 03-07-2012, 08:59 PM   #26
Wait a minute, what puller do you have? You've got me worried now. I was going to switch out the alternator and put on U/D pulleys and an electric fan while I was in there changing out the pump.
Old 03-07-2012, 09:06 PM   #27
nothing to worry about.
you only need the puller to get off the power steering pulley.you can rent it at autozone for cheap.the alternator pulley just unbolts.i cant seem to remember if the alternator is reverse threads or not.a ps puller will pull on the smaller center piece.where i went wrong was use a big puller on the outside of the pulley.it bent the pulley cause it is not very strong.the puller should also come with the piece to install the pulley back on.
also if you are adding u/d pulleys and an electric fan you may need a high amp alternator.with the u/d pulleys you alternator will rotate less per revolution of the motor.and you will be drawing more current.just keep that in mind.
hope this helps
Old 03-07-2012, 09:13 PM   #28
Thanks a bunch for the heads up, yeah i'm going with a 200 amp. That should be fine right? I never use the radio, its not even in the car right now.
Old 03-07-2012, 09:16 PM   #29
yes a 200 should cover all your needs.some alternator upgrades require a little bracket modification.but dont be scared.it is real minor.all ou do is put the bottom bolt in,rotate the alternator up, if it hits the triangular shaped part just simply grind it down a little bit.
Old 03-07-2012, 10:12 PM   #30
How much did your power steering pump cost?
Post up some pics of your 96-04 Mustang! FORDGT14 Pictures and Videos 4668 02-23-2018 08:58 PM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
Post pics of you 05-09 DA BEAST7524 2005-2010 Mustang GT 185 03-08-2012 06:22 AM
What are the best spark plugs! Csnow99gt 1996-2004 Mustang GT 18 03-06-2012 10:19 AM
Gauge lights went out Musdoyurtang 2.3 Mustang 4 03-06-2012 07:09 AM
03:08 AM
