Throttle body - Mustang Evolution
Old 03-06-2012, 10:39 AM   #1
Jesse Bach's Avatar
Throttle body
The trick flow intake manifold is made for 75mm is it okay if you use a 70mm or will it not work properly
Jesse Bach is offline   Reply With Quote
Old 03-06-2012, 10:43 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Throttle body
it will work just fine...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-06-2012, 10:57 AM   #3
Jesse Bach's Avatar
Thanks
Edelbrock #3825, 70MM Throttle Body Trojan Horse Mustang Parts for Sale and Wanted 3 06-22-2012 08:39 AM
any body in illinois Robbiemustang96 Regional Mustang Discussion 36 04-21-2012 09:03 PM
body kits kickerofdoom Pre-2005 V6 Mustang 18 03-04-2012 08:54 PM
which throttle to go with on 99 gt 1quick4.6 1996-2004 Mustang GT 15 03-04-2012 07:51 AM
fox body sway bars 2300turboford 1979-1995 Mustang GT 3 03-02-2012 08:02 PM
03:31 AM
