Just picked up Eibach Pro Kit - Mustang Evolution
Old 03-06-2012, 12:29 PM   #1
Stangit50's Avatar
Lucked out and just picked up an Eibach Pro Kit for $30....score!
Wanting to freshen up the suspension, what else should I get? Everything suspension wise is stock except 5-lug conversion front and rear. Cobra disc brake conversion front and rear.
Heard someone offered complete poly kit for the cars suspension, motor and Trans mount.
Suggestions on struts, upper and lowers, maybe tubular a arms? Would like to go coilovers in front eventually.
Stangit50 is offline   Reply With Quote
Old 03-06-2012, 04:24 PM   #2
1995boss's Avatar
What's your plan for the use?
1995boss is offline   Reply With Quote
Old 03-06-2012, 04:31 PM   #3
Stangit50's Avatar
Its a general street/strip car... I like a well handling car as I don't always race in a straight line.
How are the JMR tubular control arms that LMR sells?
Also wanting the Kenny Brown Extreme sub frame system.
Old 03-06-2012, 04:47 PM   #4
Stangit50's Avatar
Has/does anyone run the Kenny Brown Matrix subframe connectors? I have a Lincoln Weld-Pak 100, would that work for welding them in and also welding the torque box reinforcements?
ID:	42779   Click image for larger version
Name:	29550 Extreme kit installed red_0.jpeg
Name:	29550 Extreme kit installed red full view_0.jpeg
Old 03-06-2012, 05:39 PM   #5
1995boss's Avatar
I haven't personally used the JMR control arms but have heard good reviews on them for struts I hear the KYB set up is nice for street use and can be adjusted for track use as well.
---------- Post added at 06:39 PM ---------- Previous post was at 06:36 PM ----------
Or you could get the iluminas 5 way. You should be satisfied with that.
And what's your height right now?
Old 03-06-2012, 05:54 PM   #6
That welder should be fine.
---------- Post added at 06:54 PM ---------- Previous post was at 06:51 PM ----------
just check material thickness and see if your welder is rated for it.but i would bet your ok. make sure your car is level when welding everything in.
Old 03-07-2012, 06:15 AM   #7
Re: Just picked up Eibach Pro Kit
Those are used on road racing cars to further stiffen the unibody.
They would just add weight to a street or drag race car.
Old 03-07-2012, 08:16 AM   #8
Wrong. These cars benefit from all the bracing you can add. I have this system on my cobra and love it
Old 03-07-2012, 08:49 AM   #9
No, I'm not wrong. My answer may have been a bit incomplete though and your comment does have some truth in it.
They are not really necessary on any street driven or dual purpose street/drag car and there are thousands of Mustangs out there running without them to back up my claim. Therefore IMO they would just add unnecessary weight and stiffness.
They are without a doubt stronger than just sub frame connectors and they add more rigidity to a vehicle, but you have to ask yourself if that's really a good thing in a car you will be driving on the street a lot. Uni-body cars are designed to flex and give a bit to help absorb some of the ride harshness encountered in daily driving. If you remove all of that flex and give, be prepared for a stiffer more uncomfortable ride and the need to service or replace suspension parts more often as they will be worked harder than they were before.
For most people driving on the street, they would never drive aggressively enough on public roadways or on a track often enough to realize any real benefits from them to be able to justify the expense and installation.
However anyone who wishes to do so can certainly choose to install them on their cars.
Old 03-07-2012, 11:17 AM   #10
Nice! That's what I have on mine.
Old 03-07-2012, 11:23 AM   #11
mystang50's Avatar
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
[/COLOR][QUOTE="mystang50"]
I put sve upper and lower control arms on mine and the springs
Post up some pics of your 96-04 Mustang! FORDGT14 Pictures and Videos 4668 02-23-2018 08:58 PM
Eibach/Roush/Dub Springs cheap Napoleon85 2011-2014 Mustang GT 27 03-12-2012 11:02 AM
Just got a ticket today illestdomer2005 2011-2014 V6 Mustang 71 03-09-2012 08:16 PM
Just got a 98 3.8, got a couple questions damien66 Pre-2005 V6 Mustang 26 03-07-2012 03:58 PM
tune up kjunitalian 1996-2004 Mustang GT 4 03-05-2012 04:15 PM
03:34 AM
