Whats ot called?? - Mustang Evolution
Old 03-06-2012, 06:11 PM   #1
89white GT's Avatar
Region: Iowa
Whats ot called??
Whats the name of the whole in your rear bumper that is attached to your gas tank? I filled up my tank today and it spit out a little gas? Wondering what this means?
---------- Post added at 07:11 PM ---------- Previous post was at 07:11 PM ----------
Hole*
89white GT is offline   Reply With Quote
Old 03-06-2012, 06:12 PM   #2
the filler tube?
Old 03-06-2012, 06:15 PM   #3
89white GT's Avatar
Region: Iowa
Does it come out the bottom right of your rear bumper?
Old 03-06-2012, 06:18 PM   #4
the filler tube goes from the tank to where you fill it at.the cap screws on to it.the fuel filter is also right behind the bumper.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
usualy the that tube is what leaks when you have this kind of problem
Old 03-06-2012, 06:31 PM   #5
89white GT's Avatar
Region: Iowa
That is what I'm talking about
Old 03-06-2012, 06:40 PM   #6
hmmm... i am having a tough time figuring out the pic.i even looked at mine. im suremsomeone else can help though.
Old 03-06-2012, 06:50 PM   #7
Titus Wadicus
svtlx's Avatar
Re: Whats ot called??
is it the vent tube? ive swapped my pump a few times and not sure y im actn like a newby...lol
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-06-2012, 07:06 PM   #8
89white GT's Avatar
Region: Iowa
There's a nickel size hole in the bottom left. That's out of my rear bumper cover. Then there's the tube coming from it running up
---------- Post added at 08:06 PM ---------- Previous post was at 07:50 PM ----------
The hole looks like a bolt in the picture.
Old 03-06-2012, 07:17 PM   #9
i think svt is right. vent tube
Old 03-06-2012, 07:37 PM   #10
Cobrarunnin9s's Avatar
It's a vent tube or the body drain tube. The fuel filter is on the front side of the tank directly above the rear differential.
Cobrarunnin9s is offline   Reply With Quote
Old 03-06-2012, 08:00 PM   #11
93slowstang's Avatar
It should be the drain from under your fuel door incase you over fill it won't hold any fluid.
Old 03-07-2012, 06:27 AM   #12
+1 - That is it.
Old 03-07-2012, 01:18 PM   #13
89white GT's Avatar
Region: Iowa
Nice! Thanks errrrrbody
Whats the worst car deal you've ever had? 1995boss The Bar 19 03-06-2012 04:42 PM
Whats it worth 2003SonicBlue Mustang Wheels & Tires 5 03-06-2012 02:08 PM
What is this part called on 95 Gt StangGirl 1979-1995 Mustang GT 8 02-26-2012 11:56 PM
Whats a good starter? 93_347foxbody 1979-1995 Mustang GT 8 02-24-2012 05:25 PM
Whats this Blackedout Pre-2005 V6 Mustang 2 02-22-2012 02:53 PM
04:19 AM
