2 more weeks - Page 2 - Mustang Evolution
Old 03-14-2012, 07:40 AM   #36
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
Originally Posted by WhiteCobra94 View Post
New valve covers came, and intake spacer , just left the shop, motor goes in Thursday!!! Hope these valve covers work!!!
i dont think u will have any issues. i dont like the way the chromes covers seal up after they been on and off a few times... so i ended up getn ford motorsports..
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-14-2012, 09:02 AM   #37
WhiteCobra94's Avatar
Yea, ..... I've had it with these valve covers, finally sold the cobra ones so it was a even swap for me !!
The only other prob I had with the motor and the ONLY mod I bought used (never buying used parts again) we're the crane cam 1.6 rocker arms , torque them down and they would not adjust , they were shot so I ending up buying new ones!!!
Old 03-14-2012, 09:09 AM   #38
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
thats wut happens when u buy the good stuff lol. i just got the pedestal. if they dont adjust right i know its pushrods... makes my life less complicated.
Old 03-14-2012, 09:20 AM   #39
Well I bought the pedestal to stud mount conversion kit from crane cams do I can use the rockers , soooooooo I sent the kit back and buy the pedestal mount ones !
Old 03-14-2012, 03:27 PM   #40
Re: 2 more weeks
For a street car the pedestal mounts are the best solution in most cases.
For race cars the adjustables have their advantages too.
On the old solid lift cams we used to use rocker arm adjustments to move the engine's power band up and down the RPM scale a bit to help compensate for air temp/humidity, altitude or track variations.
Old 03-14-2012, 04:14 PM   #41
I'm actually happy I ended up buying brand new pedestal rockers , makes me feel better knowing that I didn't use any used parts lol!!
Old 03-20-2012, 06:16 AM   #42
Motor is in !!! Getting excited now! Lol
Old 03-20-2012, 07:23 AM   #43
Re: 2 more weeks
All right, progress!
Old 03-21-2012, 08:13 AM   #44
Taxman's Avatar
Every time I look at your car I want to make mine look like it... ( the front end an hood) what kinda front bumper is that? An did you lower your car?
Taxman is offline   Reply With Quote
Old 03-21-2012, 08:17 AM   #45
The bumper is 94-98 cobra, 3.5 SVO cowl hood, lowered 1 1/2 inches all around
Old 03-27-2012, 01:53 PM   #46
Well she started on the first try..... still idles rough but SCT-chip isn't hooked up , new fuel pump isn't in and the timing isn't set!
Here's a quick video , isn't the greatest but I'll have a better one coming!!!
Old 03-27-2012, 02:14 PM   #47
Re: 2 more weeks
Allright!
Old 03-30-2012, 02:17 PM   #48
Ok everything is installed BUT!!! The car stalls randomly and it's just flat when you try to hit on the gas, the idle hangs up to, I have the SCT-4bank chip in and still doesn't seem right, I know when I ordered it they didn't ask me some mods that I thought have to be tuned I don't know, what do you guys think?
(P.S. the gas that's in the car right now has been in there for over a year)
Old 03-30-2012, 02:26 PM   #49
Re: 2 more weeks
Call them back and question them about it.
Why do you have the chip? (Memory Refresh)
Stale gasoline shouldn't cause those issues unless it is contaminated or completely flat, which shouldn't happen in that amount of time. I've had old cars that have sat for up to 3 years and they'd start and run ok on the old gas.
Old 03-30-2012, 02:33 PM   #50
I did my swap which is
- 302 bored .40 over to 308
- Edelbrock Performer Heads
- Edelbrock Performer 5.0 intake
- Trick Flow 1 inch intake spacer
- Trick Flow Stage 1 Cam
- 1.6 rockers
- 75mm throttle body
- 75mm mass air sensor
- 24lb injectors
- CAi
- full off-road exhaust
- pro billet distributor
All pumps and sensors are new
Rebuilt trans with a B&M Hole-shot torque converter With 4.10 rear
And SCT 4bank chip from AM
---------- Post added at 02:33 PM ---------- Previous post was at 02:33 PM ----------
- 1.6 rockers
- 24lb injectors
- CAi
Everything was installed at once
Old 03-30-2012, 02:39 PM   #51
Re: 2 more weeks
Thank you, sorry to have you type it up, but I had forgotten exactly what you were doing.
Try it without the chip.
I don't see anything that specifically requires one for it to run.
Your MAF is calibrated for the injectors right?
Old 03-30-2012, 02:45 PM   #52
You MAF is calibrated for the injectors right?
Yes it's calibrated
---------- Post added at 02:45 PM ---------- Previous post was at 02:44 PM ----------
Sounds like I'm gonna have to custom tune it!!
Old 03-30-2012, 02:55 PM   #53
Re: 2 more weeks
Yes it's calibrated
You shouldn't have to custom tune it.
My car has equivalent or maybe even a few more mods and it runs just fine off the stock ECU.
You have an issue or issues somewhere in the system.
Old 03-30-2012, 03:23 PM   #54
But I was always told for sn95 mustangs when you add heads, cam, intake that it needs to be tuned
Old 03-30-2012, 03:30 PM   #55
McNassty's Avatar
I didn't have to, I just got a tune for a more aggressive fuel and timing curve
McNassty is offline   Reply With Quote
Old 03-30-2012, 03:41 PM   #56
Well it's installed now, but i don't know what other issues there would be, everything is new from motor, ignition, trans, rear. I don't know im just getting frustrated now!!!!
Old 03-30-2012, 03:46 PM   #57
did you try removing the tune like trojan suggested?the tune may just not be working right for ya
---------- Post added at 04:46 PM ---------- Previous post was at 04:42 PM ----------
also once u remove the tune you may have to drive it a little bit so the ecu can relearn its parameters
Old 03-30-2012, 03:51 PM   #58
I'm gonna drive it tonight I'm heading to shop now ..... I have a guy that works at a performance shop he said to bring it over and he'll hook it up to the computer and see what or if he has to adjust something's !
Old 03-30-2012, 04:55 PM   #59
Also my buddy that did all the work and test drove it , his daily driver is a 780rwhp Shelby GT500 so I'll see how my car rides in a few!
Old 03-30-2012, 05:01 PM   #60
Re: 2 more weeks
Good luck & happy tire smoke!
Old 03-30-2012, 06:42 PM   #61
Ok I just left shop and I might have panicked early the car idles awesome,!!!! Right around 950-1000rpms,
When you rev the car sounds amazing , as so as you put it in drive and give it gas , you can feel it wanting to go but something's holding it back , kinda like clogged cats but my exhaust is off road,
Does this sound like something is wrong with my mass air sensor?
Old 03-30-2012, 07:16 PM   #62
Re: 2 more weeks
Maybe, but it sounds more like a timing or fuel supply issue.
Here's how to test the MAF.
Name:	MAF Tests .jpg
Old 03-30-2012, 07:38 PM   #63
Right now the timing is at 10 degrees and fuel pressure is 38 psi
Old 03-30-2012, 07:55 PM   #64
Lapida's Avatar
Amazing sound!
Lapida is offline   Reply With Quote
Old 03-30-2012, 07:58 PM   #65
Re: 2 more weeks
That fuel pressure is at idle correct?
What does it do when you rev it?
Old 03-30-2012, 08:09 PM   #66
I don't what it's at , at rev , but I have a brand new fuel pressure reg, and new 190 pump
Old 03-30-2012, 08:16 PM   #67
Re: 2 more weeks
Did you set the pressure at idle with the vacuum hose disconnected and plugged?
How is your TPS?
Maybe it is not sensing the throttle position correctly.
Old 03-30-2012, 08:22 PM   #68
I personally didn't set the pressure but I'll find out tomorrow how he did it!
---------- Post added at 08:22 PM ---------- Previous post was at 08:19 PM ----------
I'm gonna pick up a new TPS and idle control valve this week! The hard part is over now it's little stuff lol
Old 03-30-2012, 08:30 PM   #69
Re: 2 more weeks
Yup, get out the Raid spray, it's time to "get the bugs out".
Old 04-20-2012, 04:37 PM   #70
Finally this nightmare is over!!!! There was nothing wrong your damaged with the car, turned out the chip from AM was not the way to go for me. I dropped the car off Wednesday and this morning had the car custom dynoed tune by (2nd street speed in Pa) with a 302 bored to 308 , HCI, full off-road exhaust the car dynoed at 304rwhp / 314ft/tq,
I'm picking the car up tomorrow I'll have pics and videos to follow!!!!
Thank you everyone for the help and info over the past year !!!!
Broke it some more, pic of busted oil pan inside... Project Pony Pre-2005 V6 Mustang 11 03-22-2012 06:31 PM
I'm in love: FRHP, MGW, Calipers, and More avengnd 2011-2014 Mustang GT 26 03-15-2012 11:38 AM
a couple more swap pics... svtlx 1979-1995 Mustang GT 30 03-07-2012 08:12 PM
what do i do next for more power? angelofrat42 2005-2010 V6 Mustang 7 03-07-2012 05:26 PM
More goodies for me! SCT tuner ?'s Project Pony Pre-2005 V6 Mustang 2 02-23-2012 01:04 PM
04:40 AM
