2 more weeks - Mustang Evolution
Old 03-07-2012, 04:45 PM   #1
WhiteCobra94's Avatar
2 more weeks
Coming down to the last week or 2, engine bay is getting painted tomorrow, new motor goes In this weekend !!! Then START'HER UP!!!!
ID:	42879   Click image for larger version
ID:	42881   Click image for larger version
ID:	42883   Click image for larger version
ID:	42885   Click image for larger version
ID:	42887   Click image for larger version
Old 03-07-2012, 05:38 PM   #2
89 coupe's Avatar
I'm doing the same to my 89 coupe right now. Did you go with stroker guts ?
89 coupe is offline   Reply With Quote
Old 03-07-2012, 06:05 PM   #3
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
sup wit da fender? did it catch fire?
are those 1.7rr?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-07-2012, 06:37 PM   #4
Yes 1.7 rrs, and I sanded my fender down to the metal for paint , so it needs bondo and paint , I do all myself except bondo work
---------- Post added at 08:37 PM ---------- Previous post was at 08:36 PM ----------
347
Old 03-07-2012, 06:43 PM   #5
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
wut gear and trans u running? is that an e-cam or tfs stage 1 u running?
Old 03-07-2012, 06:53 PM   #6
Trick flow stage 1 cam, it's a built AODE with a B&M 3000rpm stall hole-shot torque converter , the one in the pic is my old one , getting changed out
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
4.10 gears
Old 03-07-2012, 06:58 PM   #7
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
should be a good runner. i got built aod for mine. e-cam and 1.7 like urs...
standard stroke, 3.45 gear, and 11psi on a centri...
seems like we got our set-up from same person...lol.
Old 03-07-2012, 07:04 PM   #8
Yea I can't wait , 2 years of building , painting and re-doing my interior is paying off
Old 03-07-2012, 07:21 PM   #9
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
check out my thread in pushrod... 96 conversion pics... i did my interior too...it was saddle, now all black..
Old 03-07-2012, 07:30 PM   #10
I still have original seats but new dash, carpet, gauges
ID:	42897   Click image for larger version
ID:	42899   Click image for larger version
Old 03-07-2012, 07:32 PM   #11
very nice. are those roller rockers scorpion? i just installed 1.72 scorpions and they look pretty similaiar. if so they are great rockers.they are actually warranties for life.
the motor looks beastly.
---------- Post added at 08:32 PM ---------- Previous post was at 08:30 PM ----------
ijust looked again.there probably frpp s
Old 03-07-2012, 07:34 PM   #12
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
those scorpians u got... were u able to use your stock pushrods? those r prolly proform rockers im thinkn .
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
that looks awesome... i just dyed my carpet... and still rockn a 120 speedo
Old 03-07-2012, 07:36 PM   #13
I had to use different pushrods because my heads required them.trickflow 170s. I went with trickflow 6.75 " chromolly rods.they work great.
---------- Post added at 08:36 PM ---------- Previous post was at 08:36 PM ----------
Yes that interior is fits.
Old 03-07-2012, 07:37 PM   #14
No they are 1.7 Proform rockers,
Old 03-07-2012, 07:40 PM   #15
proform.haha i knew that.lol
Old 03-07-2012, 07:44 PM   #16
I had crane cam stud mounted rocker arms with the conversion kit but the rocker arms were shot, once torqued down they still had play in them so I ended up buying new ones and I went a little cheaper and got the proform's hopefully they work good!!!
Old 03-07-2012, 07:51 PM   #17
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
wut pushrods u got... i got the same proforms on e7's and im using +.117 over stock
---------- Post added at 09:51 PM ---------- Previous post was at 09:46 PM ----------
my proforms have survived several debackles..lol. sum are scratched up and dented from sum piston/valve/broke spring issues. but they work great. my proforms are on 2nd blower motor and 2 n/a ...they are very good...and i think they are chinese if im not mistaken. how much were urs? i think i gave 130-140 shipped from ebay back in 05 i think..
Old 03-07-2012, 07:53 PM   #18
Ford racing 6.272
---------- Post added at 09:53 PM ---------- Previous post was at 09:51 PM ----------
$180 + shipping I think they came to $198
Old 03-07-2012, 08:04 PM   #19
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
Ford racing 6.272
where did u get urs? american muscle?
Old 03-08-2012, 03:57 AM   #20
I got them at summit racing
Old 03-09-2012, 04:02 AM   #21
Taxman's Avatar
What kind of hood Is that?
Taxman is offline   Reply With Quote
Old 03-09-2012, 04:53 AM   #22
3.5 inch svo cowl hood
Old 03-09-2012, 08:06 AM   #23
Taxman's Avatar
Thanks looks good man..
Old 03-09-2012, 08:27 AM   #24
Thank you!!
Old 03-10-2012, 09:30 AM   #25
I am having trouble with valve cover fitting , I bought the black cobra valve covers but my elbow adaptor turns right into the oil fill neck, my rockers are hitting my stock valve covers so I ordered Moroso 68450 chrome valve covers and 1 inch intake spacer , with these valve covers once they are set I can drill wherever I want my oil fill to go and just pop in breather caps
Old 03-10-2012, 10:19 AM   #26
Re: 2 more weeks
But couldn't you have just swapped sides with the Cobra covers and put the oil fill on the driver's side?
Old 03-10-2012, 11:08 AM   #27
We tried , still had clearance issues !
Old 03-10-2012, 12:06 PM   #28
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
i ran into the same problem...obviusly cause we got the same stuff lol. i ended up using ford racing valve covers...
bbk doesnt sell a 1inch.... but they do have 3/8th @ almost 100 bucks a piece after tax... and of course i needed two so i could get full inch.
i was so effn mad...i called bbk twice and gave them a piece of my mind.
then to top it off... my bbk strut tower brace wont work with a bbk intake on sn95...
Old 03-10-2012, 12:30 PM   #29
Lol yup I'm in the same boat!!! I actually found a trickFlow 1 inch spacer for edelbrock intakes
Old 03-10-2012, 12:42 PM   #30
Titus Wadicus
svtlx's Avatar
Re: 2 more weeks
u got a better deal than me... when it was all said and done. i got 700 bucks tied up in that stupid thing. my gf bought me the intake for xmas a while back, but im sure a couple hundred of my dollars were tied up in there somewhere.. lol.
im not gonna trash talk them... cause brian and the rest of the crew at bbk are pretty good peeps. but i expressed my displeasure about the whole deal...
and told them that they should have made a 1inch, cause im sure im not the only one wit a foxbody intake swap on a sn95
Old 03-10-2012, 01:10 PM   #31
Loc: Austin,TX
Re: 2 more weeks
That motor is sexy as hell,looks great!!
Old 03-10-2012, 01:55 PM   #32
Thank you!!
---------- Post added at 03:55 PM ---------- Previous post was at 03:53 PM ----------
Yea there are a few company's that should make better mods, and bolts for sn95's , when I started the build I bought a new timing chain cover and I needed new bolts it took me forever to get the right lengths cause not even apr makes them for 94-95
Old 03-10-2012, 02:30 PM   #33
FORDGT14's Avatar
Just finished mine in my 99 Gt.
ID:	43146   Click image for larger version
ID:	43148   Click image for larger version
ID:	43150   Click image for larger version
FORDGT14 is offline   Reply With Quote
Old 03-11-2012, 07:19 AM   #34
Nice!! Looks sweet!!!
Old 03-13-2012, 08:29 PM   #35
New valve covers came, and intake spacer , just left the shop, motor goes in Thursday!!! Hope these valve covers work!!!
ID:	43507   Click image for larger version
ID:	43509   Click image for larger version
Broke it some more, pic of busted oil pan inside... Project Pony Pre-2005 V6 Mustang 11 03-22-2012 06:31 PM
I'm in love: FRHP, MGW, Calipers, and More avengnd 2011-2014 Mustang GT 26 03-15-2012 11:38 AM
a couple more swap pics... svtlx 1979-1995 Mustang GT 30 03-07-2012 08:12 PM
what do i do next for more power? angelofrat42 2005-2010 V6 Mustang 7 03-07-2012 05:26 PM
More goodies for me! SCT tuner ?'s Project Pony Pre-2005 V6 Mustang 2 02-23-2012 01:04 PM
10:07 PM
