Malfuntioning Tachometer - Mustang Evolution
Old 03-07-2012, 09:58 PM   #1
Odub421's Avatar
I have a 1992 LX 5.0. When I turn the car on, the tachometer rises up to about 4000 rpms and stays there. Even while driving, the tach stays at 4000 rpm and hardly moves. Any ideas what's causing the problem?
Odub421 is offline   Reply With Quote
Old 03-08-2012, 12:24 AM   #2
Re: Malfuntioning Tachometer
Your tachometer is shot.
Old 03-08-2012, 08:36 AM   #3
deadsp0t's Avatar
Now you have an excuse to go buy an auto meter
That's unimpressive
Old 03-08-2012, 09:15 AM   #4
Odub421's Avatar
Is it possible to change out the factory tach without replacing the entire instrument cluster?
Old 03-08-2012, 11:51 AM   #5
88fox's Avatar
I have the same issue but with my fuel gauge it goes all the way past full
88fox is offline   Reply With Quote
Old 03-08-2012, 12:00 PM   #6
Yes, I believe you can.
If only the fuel gauge acts up then it is likely just the fuel gauge or sending unit in the tank..
If they all act up there is an adjustment on the back of the gauge panel.
Read in your Chilton's manual on how to locate and adjust it.
Old 03-08-2012, 04:14 PM   #7
88fox's Avatar
I'm guessing its the sending unit then because the gauge works normal it just goes all the way passed F and stay there
Old 03-10-2012, 12:56 PM   #8
Titus Wadicus
svtlx's Avatar
you can replace just the tach.. the cluster splits into sections...
2 gauge sections..
tach
and speedo
be sure the tach u get is for your year car. i think 89 or 90 the clusters changed a bit. at the bottom corner. u can trim it with tin snips or a grinder. its just the corner, and its not visible when installed.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-10-2012, 02:23 PM   #9
Odub421's Avatar
Thanks everyone for the info.
Tachometer beanocook Classic Mustangs 3 08-17-2011 08:09 PM
03:41 PM
