foxlake E-Street heads - Mustang Evolution
Old 03-08-2012, 09:08 AM   #1
cgarray17's Avatar
Im just going to do heads come this spring with 1.7 rr and found these and was wondering what you all think of them for the price? Also im going to do a 331 boss short block next winter after i save up this summer so thats why i was looking a ported heads a little. Thanks
http://www.foxlakeracing.com/edelbrock_e-street.php
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
cgarray17 is offline   Reply With Quote
Old 03-08-2012, 10:21 AM   #2
Re: foxlake E-Street heads
Fox Lake Power Products, intake manifolds, assembled shortblocks, modular shortblocks, CNC modular heads, P-51 installation, comp cams, crower, ferrea components 1999
Had a hard time determining exactly what they were selling and for what price.
Are these what you are looking at - Edelbrock E-Street 5023 ?
If so they don't flow very much and a larger head might be better for your 331.
Look at the AFR 185 & 205 heads for your application.
Old 03-08-2012, 10:31 AM   #3
cgarray17's Avatar
I was looking at the set from foxlake, they are ported and cnc cambers with 2.02 and 1.60 valves and new springs good till .600" lift cam and flow 300 cfm at .600". I would not get the stock castings as i can tell they would be too small for a 331. But they are going on a stock shortblock now.
94 GT Convertible
Old 03-08-2012, 10:46 AM   #4
2.02 valves may not work on a stock shortblock.
Old 03-08-2012, 10:54 AM   #5
cgarray17's Avatar
Even if its only the stock cam? I think the TF has 2.02 valves and the rep told me they would clear stock pistons even with the tfs 1 cam installed straight up.
94 GT Convertible
Old 03-08-2012, 10:59 AM   #6
TFS changes the angle of the valves to allow for more clearance. So they work where others will not.
Why don't you just go with their 360 HP HCI top end kit?
Then you will know they will work and you get a proven performance combination.
Old 03-08-2012, 11:06 AM   #7
cgarray17's Avatar
That is what i might just do at this point. Just more money then i was looking to spend right now and doing a cam with the motor still in the car im told is a major PITA. But maybe i will just do tf heads and leave it at that till next winter? Idk lol just trying to get a little more power for the summer and have heads that will still work good with a 331 later on.
94 GT Convertible
Old 03-08-2012, 11:17 AM   #8
I'd really recommend using either their HCI kit or another major manufacturer's kit.
That way all of your components work together instead of against each other as so often happens in pieced together combinations.
You could just buy the heads and wait to get the matching components later, but with heads only you may be disappointed in the results until the other components are added.
Old 03-08-2012, 11:27 AM   #9
cgarray17's Avatar
Well i have a street heat intake atm sitting in my room so it would be a head and intake swap. But how hard would u say it is to do a cam when i would already have the heads off? like im guessing i will need to take the radiator out, how about the AC condensor?
Old 03-08-2012, 11:36 AM   #10
93slowstang's Avatar
If you're doing the heads it isn't that much more work to do the cam. Yes the radiator has to come out. I
Old 03-08-2012, 01:28 PM   #11
WhiteCobra94's Avatar
I read up on the e-street heads if you get them make sure you DO NOT rev past 5500rpms you will cause major valve float, if you can save a extra $300. And get the edelbrock performer 5.0 heads!!
Old 03-11-2012, 12:25 PM   #12
Few things on the E streets
- i saw people were asking about the price - the price is 1599.99 fully ported, assembled with manley hardware,each one hand made in house by Ron and jim at fox lake
- I am bias for a few reasons - im a huge fan of their work, they are building my motor which is a 347 stroker,and i have their new E streets going on it
- my heads are actually being made in their video series which you can watch on youtube by searching for fox lake power products.
Ron goes thru the whole build process in a three part series - i would watch the series and decide for yourself whats right for you and your car.
also - these heads are good up to 7000rpm @ 600 lift
Heres the link to the first episode of the edelbrock head build series - Welcome to Fox Lake Power Products Edelbrock "E Street" Cylinder Head Build Part 1 - YouTube
And if you wanna see these heads running on a 331? - here ya go
on run in stand - 331 stroker built by fox lake - YouTube
And heres the dyno - 331 stroker by Fox Lake Dyno Test - YouTube
slivers is offline   Reply With Quote
Old 03-11-2012, 02:14 PM   #13
Nice, but if you are going for power and flow why not start with the Victor or RPM Xtreme heads?
Old 03-11-2012, 03:22 PM   #14
Ron is a smart guy, he wanted to make a affordable head -most of his business is for pro's and track cars,and high end dollar porting... he wanted to provide a race ready head, out of the box for the people who wanted a entry level priced quality head, hes researched all these other entry level heads in house and figured he could make a fox lake quality head for entry level budgets... i chose these heads, not for price - but for the love and care he puts into every set, and he add's his secret valve seat angle that hes known for, the tear drop port, all of his high end techniques are in the heads program, the valve guides are hand honed, theres alot of love that goes into these you just wont find in the other similar priced and more expensive flow rated heads...you just get ALOT for very little investment, I could of had any head by Ron and i chose the E streets. They arent mass produced, you order them and they make them according to your specs
Old 03-11-2012, 03:46 PM   #15
I'm not doubting his work or quality.
I just wondered why not pick a better set of heads to begin with if you are going for increased lift and flow capabilities.
P.S. I love my machinist too, but mainly because he's my cousin.
Old 03-11-2012, 03:57 PM   #16
On no... i wasnt saying or meaning that.. im sorry.. i didnt answer question very well .. im sorry... im not sure why he chose the E streets, ill ask him next time i see him
Old 03-11-2012, 04:51 PM   #17
You have nothing to be sorry for.
He may have chose them just to showcase what he can do with them.
I just thought maybe there was a particular reason for choosing those heads.
Old 03-12-2012, 05:19 AM   #18
whitecobra94 - those numbers would be correct if it were a stock head, the fox lake version will keep you safe past 7000rpm if you watch the head series you will see this is accomplished -
If you are going to use the fox lake heads i would suggest changing your cam to match the heads - i have a custom cam made by Ron @ fox lake to match my heads and set up - letter cams will not get you there
I would also have your intake port matched -
Ron has angled the valves in the e streets - just as he would in his high end heads - they will work with stock pistons and they are set at 2.02
Do not waste your money on AFR unless you want wrong numbers and cheap internals - again - if its doubted fox lake is making a better head - watch the head series on youtube and watch how Ron achieves numbers THAT WILL CRUSH AFR -
For you trick flow fans - Ron IS trickflow - he is their technology - he was the first to cut on tricks back in the late 80's - when summit racing bought trick flow - ron left and started his own shop and continued to research and develop better products. Trick flow STILL sends all their port work to Fox lake.
Your buying Rons technique in trick flows,and they are great heads, but its actually astounding whats been done with the E street - its not a E street - its a fox lake head with a E street casting
---------- Post added at 06:19 AM ---------- Previous post was at 06:05 AM ----------
i think he chose them to shut down pro comp and AFR - hes pretty pissed those companies are charging what they do for CRAP.
Sorry for the CRAP comment. just my opinion
Not everyone can afford fox lake heads - but with the E streets now everyone can afford a quality head, hand made in america - For anyone who is on the fence or if u you wanna know more... call fox lake..call the shop and talk to ron and tell him your plans and he will honestly push you in the right direction and he can elaborate on why he chose the E street, and hell help ya out even if you choose another direction, or even if its not with him, hell pass on his knowledge - he likes talking to people on this subject and hes very in tune to it all.
Old 03-12-2012, 06:46 AM   #19
Yea I just check out the site
Old 03-12-2012, 06:31 PM   #20
sounds very intersting.you seem to know alot about the product.i havent checked out the videos yet but i will. i will disagree that all of the other top brands you named are crap.lots of people have used the afr with great results.i strayed away from the afr 185 because i didnt want to kotch my pistons.i am running the trickflow 170s, and i am very pleased so far but havent really got to do much testing of them yet.
---------- Post added at 07:31 PM ---------- Previous post was at 07:30 PM ----------
let us know how the heads run on your 331 when you get it all done.like dyno numbers tract times etc. you have me very interested now.
Old 03-12-2012, 07:30 PM   #21
Trick flow makes awesome stuff,fox lake offers the whole trick flow line as well...im not meaning to bash AFR or user's of their stuff... different strokes for different folks ...im speaking simply from a budget stand point,and anyone that knows the reputation of fox lake,take that and it add it to the E street casting,its beyond a good grab i think, i thought so when i chose them for my motor, but im only going after 450rwhp on a street car
Old 03-12-2012, 07:49 PM   #22
I personally never used afr so u didn't offend me.but I have read nothing but great reviews,that's all.
He does seem like he really knows his stuff though
Old 03-13-2012, 05:05 PM   #23
Street Racing Posts Will No Longer Be Allowed Brent ME Site Help & Announcements 12 11-07-2015 11:59 AM
Trickflow Heads & Cams FORDGT14 1996-2004 Mustang GT 29 04-18-2012 10:37 AM
Wanted: Street bike 1lowGT Mustangs for Sale and Wanted 50 04-06-2012 12:55 PM
1966 289 with 302 heads? ThatBlack66 Classic Mustangs 2 03-10-2012 07:46 PM
Npi or pi?? port or buy new heads mhobbs 1996-2004 Mustang GT 33 03-05-2012 12:07 PM
07:00 PM
