how rare is Ford Motorsports 160mph speedo? - Mustang Evolution
Old 03-08-2012, 09:28 AM   #1
Stangit50's Avatar
I have a 160mph Ford Motorsports speedometer, how rare and what did they come on?
I replaced my speedometer cable and VSS but its not working. I've verified the speedometer works and was told the clip holding the gear or the gear in the Trans tailshaft is stripped. How hard to fix?
Stangit50 is offline   Reply With Quote
Old 03-08-2012, 10:24 AM   #2
Re: how rare is Ford Motorsports 160mph speedo?
Don't know that I ever saw or heard of one.
You'll probably have to tear down the transmission and remove the tailshaft to get to it.
Depends on what you have.
Old 03-08-2012, 01:10 PM   #3
Stangit50's Avatar
I've heard the Saleens came with 160mph speedometers. Mine doesn't say saleen just Ford motorsports.
Old 03-08-2012, 03:41 PM   #4
Meansaleen's Avatar
1987-1993 Saleen's came with a 170mph speedo. The 1989 Saleen SSC came with a 200mph white face speedo. You can usually find both on e-bay.
Meansaleen is offline   Reply With Quote
Old 03-08-2012, 03:50 PM   #5
Stangit50's Avatar
Well where did my 160mph come from? Haven't seen another.
Old 03-08-2012, 03:57 PM   #6
93slowstang's Avatar
Either the svo or some ssp cars.
Old 03-08-2012, 03:57 PM   #7
You may have an optional or add on speedometer.
I'm sure if you Google it you can probably turn up some more info on it.
Old 03-08-2012, 05:52 PM   #8
SleepingStang's Avatar
The 160 mph speedo came out of an SSP car if it doesn't say Saleen on it. I have a 92 LX that was a Nebraska State Patrol car and have done a lot of research on the SSP's. I was even able to track down the officer that drove the car. Your working issue could be caused by the toothed gear in the transmission housing. Not difficult to change. There is 1 bolt holding the cable housing into the trans. Remove it and give a tug on the cable.
SleepingStang is offline   Reply With Quote
Old 03-08-2012, 08:01 PM   #9
I had to change my gear and it was in the Chilton manual. Took about five minutes.
JayKranz is offline   Reply With Quote
Old 03-09-2012, 03:33 AM   #10
Yes, the speedo cable gear is easy to change.Not so easy, is the gear inside the tailshaft that drives the speedo cable gear.
Old 03-09-2012, 08:26 AM   #11
Stangit50's Avatar
The speedometer gear is fine. It's the one in the tailshaft that needs replaced. I haven't even attempted it yet because of wanting to switch gears. Was told the gear needs to be changed as well.
Old 03-09-2012, 08:46 AM   #12
That's what you said earlier, i thought the guys in the posts above may have misunderstood.
Yes it is best to match the drive and driven gears.
The "drive" gear is the one in the tailshaft, the "driven" gear is on the end of the speedo cable.
I had a 95 GT and the gears did not match perfectly.
It was always chewing up the driven gear.
Old 03-10-2012, 12:48 PM   #13
Titus Wadicus
svtlx's Avatar
i have a 160 motorsport for sale.... it was in my coupe...lol. they are definatley rare pieces. i seen sum new in box speedos on ebay, but i think he was askn like 250 for them... a lil pricey.. but they were new.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-10-2012, 02:27 PM   #14
Stangit50's Avatar
I like rare and unique. Always looking for unique items for my cars. I am just starting with the stang. 160mph speedometer and a rare OEM Saleen Momo steering wheel with cruise control that I found brand new and bought for $75
Old 03-10-2012, 03:25 PM   #15
Meansaleen's Avatar
Now you gotta get yourself a set of flo-fit seats if you don't have em already.
Old 03-10-2012, 03:27 PM   #16
Stangit50's Avatar
Been looking for some... all the ones I come across are trashed and still expensive!
Old 03-10-2012, 03:29 PM   #17
Meansaleen's Avatar
The closest ones to those would be the 84 SVO seats kinda similar and you can get the fabric from a few online sources.
Old 03-31-2014, 11:46 AM   #18
UDLOOZ's Avatar
I just found out that I too had a 160mph speedometer covered a white inlay gauge covers.
My car is a 88 gt so I am assuming it isn't a stock speedometer? My speedo cable needed to be replaced so while doing some further cleaning of the cluster I wondered if it had the original cluster and sure enough a 160 mph was covered by a 140 mph white gauge surface. Who would do such a thing?
How much is it worth?
UDLOOZ is offline   Reply With Quote
79-95 Ford Mustang Clutch Cable Quadrant choppa5307 1979-1995 Mustang GT 10 03-07-2012 08:14 PM
Is it really that hard?? 98StangKid 1996-2004 Mustang GT 23 03-07-2012 05:39 PM
speedo fix clark98gt 1996-2004 Mustang GT 3 03-07-2012 04:37 PM
2000 Ford Mustang Chelley Member Garages 0 03-07-2012 04:11 PM
Newbie: Is this normal? (Finding first gear & backfiring) Rim 2011-2014 V6 Mustang 9 03-07-2012 06:10 AM
09:53 PM
