Gear problem help. - Mustang Evolution
Old 03-09-2012, 08:10 AM   #1
NateNasty's Avatar
Gear problem help.
I have been installing 3.73 gears and ran into a problem. While putting them back together the two of the four gears that the pin holds fell out and I can't seem to get them back in. I have the ring and the spindle in and need to do that so I can stick the axels in and put the c clamps in. Thanks if I'm not clear I can get some pictures once I get out.
---------- Post added at 09:10 AM ---------- Previous post was at 08:52 AM ----------
Do I have to get that clip out? In scared if I take it out I won't be able to get it back in.
NateNasty is offline   Reply With Quote
Old 03-09-2012, 09:08 AM   #2
Re: Gear problem help.
I suppose you are talking about the spider gears?
Are you following directions from a manual or gear install article?
Pictures would be good.
Old 03-09-2012, 10:42 AM   #3
NateNasty's Avatar
My Manuel doesn't go into that I followed directs online and they don't go into that as well
Old 03-09-2012, 10:25 PM   #4
That's the S-Clip and it has to stay in there the spider gear cross shaft runs through it.
If the axles are installed and the C-Clips are on them, pull out on both axles as far as they will go to ensure you have enough room to slip the spider gears back into place.
Don't forget the spider gear cupped washers.
Put some Loctite on the threads of the cross pin bolt that holds the cross shaft into place.
It should look like this installed.
Name:	8.8 trac-lock.jpg
Old 03-09-2012, 11:01 PM   #5
Here's an article that might help.Traction-Lok Differential Rebuild
Smoking problem with the 5.0 1995boss 1979-1995 Mustang GT 20 03-07-2012 10:13 AM
Newbie: Is this normal? (Finding first gear & backfiring) Rim 2011-2014 V6 Mustang 9 03-07-2012 06:10 AM
clutch problem pandm0811 1979-1995 Mustang GT 5 03-04-2012 09:29 PM
Missing 6th gear in Beater Car mongo1970 2011-2014 Mustang GT 7 03-04-2012 09:45 AM
Oil Pressure Guage Problem FORDGT14 1996-2004 Mustang GT 6 03-03-2012 06:54 PM
10:33 PM
