351 swap - Mustang Evolution
Old 03-10-2012, 11:13 AM   #1
Taxman's Avatar
351 swap
Does anyone know what kinda clearance issues I'd have putting a 351 block in a 95 gt convertible?
Taxman is offline   Reply With Quote
Old 03-10-2012, 12:16 PM   #2
Titus Wadicus
svtlx's Avatar
Re: 351 swap
there arent any real clearance issues if u use the convertible motor mounts on it. u may need a 1.5-2.0 hood.
other than that it drops right in.... besides for the stuff u gotta change like 351 swap headers and stuff like that.
---------- Post added at 02:16 PM ---------- Previous post was at 02:15 PM ----------
even if u use hard top motor mounts it drops in... but like i said, u will prolly need a 2.0 cowl hood
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-10-2012, 01:36 PM   #3
Taxman's Avatar
I figured the hood... Do you know if a stock bellhousing will mount to the 351....
Old 03-10-2012, 01:39 PM   #4
Titus Wadicus
svtlx's Avatar
Re: 351 swap
is the same...
Old 03-10-2012, 01:41 PM   #5
Taxman's Avatar
Originally Posted by svtlx
is the same...
Thanks..
Old 03-10-2012, 08:14 PM   #6
Re: 351 swap
You will also need the 351W oil pan for the Fox chassis.
Old 03-11-2012, 04:11 AM   #7
Taxman's Avatar
It's not a fox... It's a 95 convertible... But looking at it I'm sure I need a certain oil pan... Do you know if bbk equal length shorties will fit a 351... The ones for a 302.. what size exhaust are you running?
Old 03-11-2012, 09:11 AM   #8
deadsp0t's Avatar
It is a fox
That's unimpressive
Old 03-11-2012, 01:43 PM   #9
Re: 351 swap
It's still a Fox chassis.
It's not likely, but it is possible the 302 headers might work.
The 351W is about an inch wider so if you have that much clearance all around they might conceivably fit.
I will be running the BBK 1 3/4" tube long tube headers (which I think they also make for the 351W) feeding into a 2.5" H-Pipe, feeding into a set of 3" (maybe Dynomax) mufflers, feeding into 3.5" tail pipes to help exhaust the added flow from the SC.
The increased size steps help by letting the exhaust gases expand as they are exhausted which increases the scavenging effect. The scavenging effect allows more air/fuel mixture to be pulled and pushed into the cylinders during camshaft overlap periods. More air/fuel = more power produced.
Old 03-11-2012, 02:10 PM   #10
Taxman's Avatar
That's good info.. My block will be in the shop Tuesday. I'm just trying to et some pointers...
Old 03-12-2012, 06:15 AM   #11
The shorty 302 headers probably wont fit, you will run into clearance issues with the steering shaft. Get the 351 swap headers, I tried to use the 302 ones in my 86.....miserable fail. I tried to dimple them to fit, again, failed
JPCooter is offline   Reply With Quote
Old 03-12-2012, 07:04 AM   #12
Taxman's Avatar
Your saying my chassis is a fox chassis? I got a Lil confused....
---------- Post added at 07:04 AM ---------- Previous post was at 07:03 AM ----------
Yea I was wondering I had some issues with the bbk shorties on my stock set up...
Old 03-12-2012, 07:42 AM   #13
Re: 351 swap
From 1989 to 2004, the Fox Chassis was used exclusively by the Mustang.
Yours is actually a Fox-4, which is a little wider and had approximately 60% of its parts redesigned.
head intake swap checklist 5.slow 1979-1995 Mustang GT 21 05-07-2012 08:02 PM
5.4 swap saxxx 2005-2010 V6 Mustang 28 03-13-2012 05:55 PM
a couple more swap pics... svtlx 1979-1995 Mustang GT 30 03-07-2012 08:12 PM
2013 or 2014 351 boss mistang? Americanrwb1 2011-2014 Mustang GT 11 03-06-2012 08:13 AM
Tranny swap 93 to 90 model auto Loudmustang 2.3 Mustang 3 03-05-2012 07:34 PM
08:34 AM
