79 5.0 oil pressure problem! - Mustang Evolution
Old 03-10-2012, 01:23 PM   #1
79fordsky's Avatar
Ok I have a 79 mustang cobra. I got it from my friend about a mont ago and he put 351 heads on it and it ran terrible and it was blowing white smoke so I took the heads off and bought new e7 heads put them on. Car runs great besides when I drive it. When it's cold oil pressure is normal 35psi then after it warms up it's below 20psi and oil starts coming out of the dipstick! So I replaces the PCV valve and it got a little better but it still does it! So my question is... What could be causing this? Thanks for future information
79fordsky is offline   Reply With Quote
Old 03-10-2012, 08:12 PM   #2
Re: 79 5.0 oil pressure problem!
Sounds like your engine bearings and piston rings are shot.
Time for a rebuild.
The bearings are worn out which gives you excessive clearance so the oil pressure falls off.
Blowing oil out of the dipstick is a sure sign of compression leaking past the piston rings.
Old 03-12-2012, 01:36 PM   #3
79fordsky's Avatar
Damn I was hoping it wasn't that! But luckily I have a 308 already in the making. I guess I'll just use the whole top end off the ol 302 goodies then slap off in there.
Old 03-12-2012, 01:48 PM   #4
Sorry to be the bearer of bad news.
Be sure you check the valves, valve guides and seals on those heads before you re-use them.
Broke it some more, pic of busted oil pan inside... Project Pony Pre-2005 V6 Mustang 11 03-22-2012 06:31 PM
Best axleback exhaust for 5.0 M3hunter 2011-2014 Mustang GT 37 03-21-2012 04:00 PM
Straight piping 1989 5.0 Dkerk8 1979-1995 Mustang GT 36 03-20-2012 10:22 AM
Tire pressure light Grabber Blue 2011-2014 V6 Mustang 4 03-10-2012 07:52 AM
Gear problem help. NateNasty 1979-1995 Mustang GT 4 03-09-2012 11:01 PM
02:29 AM
