starter stuck wont turn off!!!! - Mustang Evolution
Old 03-10-2012, 10:55 PM   #1
87_Saleen's Avatar
Region: New Mexico
I have replaced starter, starter solenoid, ignition module and checked connections. It still engages even when i unbolted the solenoid and unplugged the little red and blue wire. Maybe i put the wires on wrong or maybe the solenoid itself is now bad? It did stop when i tapped the solenoid. Any help would be great thank you
87_Saleen is offline   Reply With Quote
Old 03-10-2012, 11:13 PM   #2
five_0_85stang's Avatar
Happened to me once I walked away with the keys in my hand and the engine began to turn over...your solenoid is burned out..just replace it..lol...good luck
five_0_85stang is offline   Reply With Quote
Old 03-10-2012, 11:35 PM   #3
87_Saleen's Avatar
Region: New Mexico
Re: starter stuck wont turn off!!!!
That sounds about right lol. Thank you and ill replace it and let you know how it gows tomorrow
Old 03-11-2012, 09:31 AM   #4
Sweet make sure you don't put the bolts on too tight because that also causes a solenoid to burn out quicker..just make sure they're snug
Old 03-11-2012, 03:19 PM   #5
That happens when the contacts in the solenoids burn and stick together or the coil shorts out somehow and engages the contacts. The only thing you can do and should do quickly to prevent any burned up wires is to disconnect the battery.
Replace the solenoid and make sure your starter is not dragging, causing excessive amperage draw through the solenoid.
Off Road H pipe BigB227 1996-2004 Mustang GT 31 03-13-2012 10:31 AM
Hybrids piss me off!!! WillysYJ General Car Discussion 2 03-04-2012 11:29 AM
Speedo Off w/ SCT Tune Aggiesrok 2005-2010 Mustang GT 33 03-01-2012 12:52 PM
Time to Shine, off to the Body Guy Jeffola 2011-2014 Mustang GT 23 02-26-2012 10:23 AM
Whats a good starter? 93_347foxbody 1979-1995 Mustang GT 8 02-24-2012 05:25 PM
06:06 PM
