need advice on gt40 swap!!!! - Mustang Evolution
Old 03-10-2012, 11:49 PM   #1
87_Saleen's Avatar
Region: New Mexico
I jave a 87 5.0 with the stock e7's. I am getting ready to do the upper, lower intakes and tje heads. Any advice on how to do the swap without messing up the timing? Is there a certain way to do it or how would i adjust the timing if i do mess it up? Thank you for your response
87_Saleen is offline   Reply With Quote
Old 03-11-2012, 07:16 AM   #2
WhiteCobra94's Avatar
Are you changing the cam too? If so you have to pull your distributor, since your doing heads and intake you should do the cam also, and new rocker arms 1.6 or 1.7 for the new heads!! When your done the swap you'll need to re-time it and most likely have to get it tuned to run right!!
Old 03-11-2012, 08:04 AM   #3
Posse5.8stang's Avatar
Just take the distributor cap off and get some with out...mark where the rotor is pointing to on the distributor so when u put it back on u set it right where it goes...but if your changing the cam u need to time it again
Posse5.8stang is offline   Reply With Quote
Old 03-11-2012, 08:08 AM   #4
5.slow's Avatar
Region: Delaware
I'm about to do the same swap and read somewhere if you aren't changing the cam that you can just loosen the distributor nut and lean it forward without taking it completely out and as long as the engine doesn't get turned over you would be fine. Can't remember where I read this though.
5.slow is offline   Reply With Quote
Old 03-11-2012, 09:38 AM   #5
U could do that just remove the distributor cap and housing...that should give u enough clearance
Old 03-11-2012, 09:52 AM   #6
When I pulled my intake I left the dizzy in.by I'm not sure how much different the carbed and efi intakes are.it did make it a little more difficult but wasnt bad.
Old 03-11-2012, 03:29 PM   #7
Re: need advice on gt40 swap!!!!
You cannot "lean" a distributor just by loosening the hold down bolt.
To get it to lean you would have to partially remove it and at that point you just as well go ahead and pull it out to get it out of the way.
Old 03-11-2012, 05:36 PM   #8
5.slow's Avatar
Region: Delaware
Thanks for clearing that up. That's why you can't believe everything you read
Old 03-11-2012, 06:24 PM   #9
Foxtrot's Avatar
An easy way to do it, is mark your distributor and engine block so you know how it sits. After that you can remove it to make the intake swap easier. Then just match up the marks again when putting it back in. There are a ton of YouTube videos that can show you the process
Foxtrot is offline   Reply With Quote
Old 03-11-2012, 06:59 PM   #10
Check this video , there are a few parts , this is part 1
The video is showing you on a Chevy motor but is the same idea!!!
Check out this video
Headlight on ebay!! Siendly22 Pre-2005 V6 Mustang 12 03-13-2012 09:33 PM
5.4 swap saxxx 2005-2010 V6 Mustang 28 03-13-2012 05:55 PM
351 swap Taxman 1979-1995 Mustang GT 12 03-12-2012 07:42 AM
2005 mustang rims on a 98 mustang 98must Pre-2005 V6 Mustang 5 03-11-2012 11:11 AM
Poor stang on the trailer... Project Pony Pre-2005 V6 Mustang 1 03-10-2012 09:01 PM
04:42 PM
