95 stang - Mustang Evolution
Old 03-11-2012, 07:41 PM   #1
95 stang
My 95 mustang will not start unless I use starting fluid. Please help
95 black vert is offline   Reply With Quote
Old 03-11-2012, 07:53 PM   #2
Taxman's Avatar
You running a Carb?
Need a Lil more info bro..
Taxman is offline   Reply With Quote
Old 03-11-2012, 07:57 PM   #3
yes need more info. but first thought is fuel issue
Old 03-11-2012, 08:49 PM   #4
Re: 95 stang
no efi checked tps .99 volts closed new maf engine on a total rebuild have spark to plugs,pulse to injectors will only run with starting fluid
Old 03-11-2012, 08:52 PM   #5
you need to check fuel pressure.make sure your getting fuel and the proper pressure. can you hear the pump kick on when you turn the key?
Old 03-11-2012, 08:54 PM   #6
Re: 95 stang
Took out injectors and sprays fuel
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
yes I was at 38lbs
Old 03-11-2012, 08:58 PM   #7
then i would check the pip in the distributor next.
---------- Post added at 09:58 PM ---------- Previous post was at 09:56 PM ----------
was it running before and after rebuild?or are you on initial startup?
Old 03-11-2012, 09:01 PM   #8
Re: 95 stang
yes took it out for a drive and it ran like crap now wont run at all
Old 03-11-2012, 09:05 PM   #9
have you set your timing?
---------- Post added at 10:05 PM ---------- Previous post was at 10:04 PM ----------
also make sure your vaccums are hooked properly
Old 03-11-2012, 09:06 PM   #10
deadsp0t's Avatar
If all the mandatory requirements are in place(air, fuel, fire), the timing or plug wire placement could be to blame. Also I believe 38psi is a tad on the low side, but should start.
That's unimpressive
Old 03-12-2012, 01:36 PM   #11
Re: 95 stang
what should the pressure be at (fuel)
Old 03-12-2012, 01:45 PM   #12
95 stang
can the fuel pressure be adjusted, will a fuel regulator from a 4.6 work on a 302
Old 03-12-2012, 02:15 PM   #13
Re: 95 stang
Fuel pressure should be 38-40 psi at idle with the vacuum line removed and plugged.
The factory fuel pressure regulator is not adjustable.
You have to buy an aftermarket to get an adjustable regulator.
I doubt a regulator from a 4.6 will physically fit.
Old 03-12-2012, 02:17 PM   #14
Re: 95 stang
ok thanx will recheck pressure
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
Poor stang on the trailer... Project Pony Pre-2005 V6 Mustang 1 03-10-2012 09:01 PM
pics of youre first stang svo 2.3 Mustang 48 03-08-2012 04:35 AM
took the stang out of the garage for a nice thrash session today. 1quick4.6 1996-2004 Mustang GT 0 03-07-2012 09:55 PM
95 gt pypes cat less x pipe jedpony 1979-1995 Mustang GT 2 03-07-2012 08:40 PM
09:26 AM
