gt40 question????? - Mustang Evolution
Old 03-11-2012, 10:23 PM   #1
gt40 question?????
Did the GT40 heads and intake come factory on some 302's? If so, what years? Can I use GT40 heads from a efi 302 and use with a carburetor intake?
fordracing63857 is offline   Reply With Quote
Old 03-11-2012, 11:24 PM   #2
93slowstang's Avatar
Yes on the 5.0 explorers. 96- early 97= gt40, late 97- 01=gt40p. Yes you can use a carb intake as well.
Old 03-11-2012, 11:56 PM   #3
So I can use the GT40 or GT40p heads with a carburetor intake?
---------- Post added at 11:56 PM ---------- Previous post was at 11:56 PM ----------
Which set will I benefit the most from?
Old 03-12-2012, 12:40 AM   #4
89 Foxloco's Avatar
sorry this may be a stupid question but whats so good about the gt40 heads alot of people talk about them.. Thanks..
89 Foxloco is offline   Reply With Quote
Old 03-12-2012, 01:57 AM   #5
Yes you can use either heads. You'll see the most gain out of the gt40p heads but header clearance is an issue with the spark plugs, they do make "P" specific headers to remedy that problem.
---------- Post added at 01:57 AM ---------- Previous post was at 01:55 AM ----------
They are a cheap upgrade over the stock e7's. Larger valves and better flow. Obviously edelbrocks, trick flow and so on are better but they aren't cheap.
Old 03-12-2012, 06:07 AM   #6
You can also use bbk headers. The P headers are a little expensive. I have the bbks on my 351w, GT40p heads and carbed. The bbk shortys run about 150 to 170, if I remember correctly. I did use heat resist sleeves for my plug booots on the drivers side, passenger side was ok.
JPCooter is offline   Reply With Quote
Old 03-12-2012, 06:42 AM   #7
WhiteCobra94's Avatar
The bbk shortie headers are $209 and the equal length headers are $229 by most company's (summit, jegs, American muscle)
Old 03-12-2012, 08:14 AM   #8
Bbk are 189 and the FRP "p" headers are 239 from LRS. The extra 50 is worth not having to buy the extra boots and dealing with the headaches when changing plugs with bbk headers.
Old 03-12-2012, 09:29 AM   #9
I did notice with my bbk equal length headers the bolts the gave me only threaded in the head about a 1/4 inch , I didn't feel comfortable with that so I bought longer header bolts from Mr. Gasket
Old 03-12-2012, 10:55 AM   #10
Youre right slowstang, I had to get the bbks because I swapped in a 351w, with the gt40p heads,I dont think there are P headers for that swap. Sorry for the misunderstanding though
Old 03-12-2012, 10:39 PM   #11
No misunderstanding for me, I'm running bbk headers with my p heads so I know how much of a pita it is to change plugs. Sucks that they don't have swap headers for p heads.
need advice on gt40 swap!!!! 87_Saleen 1979-1995 Mustang GT 9 03-11-2012 06:59 PM
One question one request Silversky545 2005-2010 Mustang GT 0 03-11-2012 12:39 PM
1996 v6 boost question dhktactical Pre-2005 V6 Mustang 14 03-09-2012 11:04 PM
Bought some long tubes! Have a question Project Pony Pre-2005 V6 Mustang 1 03-08-2012 04:55 PM
Wiring harness question StevieScoops 1979-1995 Mustang GT 2 03-08-2012 05:49 AM
07:11 AM
